ls/vtec piston question
im putting together a ls/vtec turbo set up. i contacted arias pistons (they were not friendly at all) and they say to run a ls piston. cp pistons says to run a gsr piston................................which do i use? i know that on a ls head the intake and exhaust valves are the same size, and on the gsr the intake valve is 2mm bigger. i really dont want to have to fly cut the piston i just want to order the right piston. any knowledge would be helpful thanks
What bore are you using?? Thats the main thing. CP makes shelfed pistons for ls-vtecs but there 84mm+ bore for all motor, anything below they list for LS or GS-R arias just lists for the exact engine no matter the bore. Should have stayed all motor
