ls and Gsr block component compatabilites?
I am building a ls/vtec and i have a bare ls block, how much of the stuff off the gsr block will bolt up to an ls block. Parts i am wondering about are the t-belt tensoiner, theromastat houseing, the water tube in back of the block, sensors, and oilpan. I am guessing they are all the same i just want to double check, so i know what to order from acura.
thanks mike
thanks mike
All that stuff will work. I have a water pipe and a brand new tensioner still in packaging if you need.
thanks mike
What are your plans with that GSR block once you strip the stuff you need?
Mike
I thought the GS-R oil pan was different because of the block girdle? Or do you only need the different oil sump that goes with it to make it fit?
You can put a GSR oilpan on an LS block, but you cannot an LS pan on a GSR block. Thats because of the block girdle that you mentioned.
NICOSLOW
Dec 23, 2009 05:04 AM
jamal-188
Apr 29, 2002 05:40 AM
