LS rods B16 eng
Old Sep 19, 2004 | 08:37 PM
Krussty420's Avatar
Default LS rods B16 eng
Has any one ever tried to use the stock Integre LS rods in an otherwise stock B16 engine or does anyone know if there is any reason they wont work (too long?)
Old Sep 19, 2004 | 08:53 PM
HONDA_TYPE_R's Avatar
Default Re: LS rods B16 eng (Krussty420)
I would imagine that they are too long. I'm not sure of the length though. Someone correct me if I am wrong.
Old Sep 19, 2004 | 09:26 PM
Krussty420's Avatar
Default Re: LS rods B16 eng (HONDA_TYPE_R)
Far as I can tell the LS rods are 2.6416mm longer than the B16s
Old Sep 20, 2004 | 01:58 PM
bens_redeg's Avatar
arias makes a set of pistons that you use a b16 block with an ls crank and rods. 11.5 compression and it basically runs like an ls/vtec
Old Sep 20, 2004 | 03:04 PM
Kendall's Avatar
Default Re: LS rods B16 eng (bens_redeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bens_redeg &raquo;</TD></TR><TR><TD CLASS="quote">arias makes a set of pistons that you use a b16 block with an ls crank and rods. 11.5 compression and it basically runs like an ls/vtec
Get ahole of Steve at Tech43 Racing for more information.
Old Sep 25, 2004 | 02:15 PM
bens_redeg's Avatar
Default Re: LS rods B16 eng (Kendall)
yes the block has to be bored and sleeved
Old Sep 25, 2004 | 04:05 PM
Runnerdown's Avatar
You don't have to sleeve it. Thats only if you want to make a 2.0 displacement.
Old Sep 25, 2004 | 11:45 PM
Krussty420's Avatar
Default Re: (Runnerdown)
Why would you have to bore or resleve the block just to put a longer rod in an otherwise all stock B16?
Old Sep 26, 2004 | 05:44 AM
Runnerdown's Avatar
The arias pistons with the raised pin start at 81.5mm iirc.
Old Sep 26, 2004 | 07:52 AM
bens_redeg's Avatar
woops my bad thanks for the correction
Old Sep 26, 2004 | 11:21 PM
Krussty420's Avatar
Default Re: (bens_redeg)
Again, still using stock B16 pistons
Old Sep 27, 2004 | 02:47 PM
bens_redeg's Avatar
Default Re: (Krussty420)
i dont think you can do that without wrecking you motor
Old Sep 27, 2004 | 09:25 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Krussty420 &raquo;</TD></TR><TR><TD CLASS="quote">Has any one ever tried to use the stock Integre LS rods in an otherwise stock B16 engine or does anyone know if there is any reason they wont work (too long?)</TD></TR></TABLE>
Too long. Won't work, unless you add a deck plate and do some other modifications but after all of that work it's not worth it, cost-wise.
Old Sep 27, 2004 | 11:29 PM
chrisCNL's Avatar
Default Re: LS rods B16 eng (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">
Too long. Won't work, unless you add a deck plate and do some other modifications but after all of that work it's not worth it, cost-wise.</TD></TR></TABLE>
I agree...no doubt about. reliabilty goes down the hole.
CTR_B
Nov 9, 2008 05:54 PM
CTR_B
Oct 17, 2008 04:19 PM
NOman0608
Mar 16, 2008 06:57 PM
JDMeg95
Nov 7, 2007 07:03 PM
joey1320
Dec 7, 2004 09:10 AM
