Lowering my compression...
Old Sep 10, 2003 | 05:02 PM
BOOSTEDcivicB18C1's Avatar
Default Lowering my compression...
I need to get my compression down for cheap, so i figured a head gasket was the bets way, but what is the thickness i need to get it down to 8.5? and if thats not even possibly with JUST a head gasket, then whats the closest ic an get it, adn how thick for that?
...or...should i just get a d16a6 head gasket, that engine has a comp ratio of 9.1....so vent your knowledge here!
thanks for your time guys
~Mike
...oh yes! and i have a d16y8...and i want more boost! lol
Old Sep 10, 2003 | 05:56 PM
Default Re: Lowering my compression... (BOOSTEDcivicB18C1)
BUMP!
Old Sep 10, 2003 | 05:59 PM
T4eg's Avatar
whats the compression now? A inline headgasket (3mm) will drop one full point. Hope that helps.
Old Sep 10, 2003 | 06:00 PM
Turbogixxer's Avatar
Without changing your Pistons, It will be real hard you get it down that much. Why do you want it that low?
Old Sep 10, 2003 | 06:07 PM
VTECorona's Avatar
Default Re: Lowering my compression... (turbogixxer)
Turbo?
Old Sep 10, 2003 | 06:16 PM
Charlie Moua's Avatar
what motor is this for ?
why are you droping your compression?
Old Sep 10, 2003 | 06:18 PM
Default Re: Lowering my compression... (VTECorona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">Turbo?</TD></TR></TABLE>
No, If you have enough Fuel, tuning, and do not go past your limit, you are set. Lower the compression is basicly for safety. Coming from someone that has seen a STOCK GSXR 1000 (12:1 CR) be turbo'ed at 9psi of boost and make 211 rwhp. It is all about tuning and enough fuel and strengh to hold it. Now, if he wants to put a crazy set-up on his car, then maybe, but tuning is the key in everything.
Old Sep 10, 2003 | 06:29 PM
I hav ea d16y8 and i want to boost more with my td04 greddy kit with a front mount intercooler, and a apex'i vafc dyno tuned with 370cc injectors....so a 3mm should bring it down from 9.6 (stock compression ratio) to 8.6? if thats so, that'd be my best bet.
Old Sep 10, 2003 | 07:11 PM
bump
Old Sep 10, 2003 | 08:24 PM
BIZUMP!
Old Sep 10, 2003 | 08:37 PM
T4eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
but tuning is the key in everything.</TD></TR></TABLE>
I would keep the stock compression 9.6:1 is very good for turbo. Just do a few bolt ons. for example intake manifold, throtle body, no cat, free flowing exhaust, cam gear, etc and see what you can get out the stock bottom end
hyper209
Sep 30, 2006 03:56 AM
2point3h22lude
17
Jun 9, 2005 03:47 PM
vtekthis
Nov 2, 2004 07:17 PM
prdtr15
Sep 25, 2003 03:45 PM
