Looking for SOHC VTEC dyno's
Old Jul 3, 2002 | 10:21 PM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Default Looking for SOHC VTEC dyno's
naturally aspirated. D16Z6 or D16Y8. if you know of any please post or link. thanks.
Old Jul 3, 2002 | 10:55 PM
LshatchTurbo's Avatar
New User
Default Re: Looking for SOHC VTEC dyno's (frank@b16a.com)
Try here:
http://www.importreview.com
Old Jul 3, 2002 | 11:11 PM
Banned
Default Re: Looking for SOHC VTEC dyno's (lshatchturbo)
been there already. nothing on NA D motors.
[Modified by frank@b16a.com, 12:11 AM 7/4/2002]
Old Jul 4, 2002 | 08:28 AM
builthatch's Avatar
MiG-21 superfan
http://www.jgenginedynamics.com/Imag...0hp%20crop.jpg -this is a mildly built z6...
Old Jul 5, 2002 | 09:29 AM
Moosilla's Avatar
Frank
I am not making crazy power ... just enough to be competitive inmy Solo1 class ... So I do not know if these will help .... these are some older plots before the cam .... D16Z6, NA, I/H/E Flywheel, chipped ECU, http://www3.sympatico.ca/delacour/
I have not had the time or patience to upload the latest plots ....I am currently up to 128HP and 110 ft/lbs at the Wheels .... with some more tuning on the way (Cam and Ignition) ... e-mail if you would like some more info
Cheers
Moose
Ps Dave "Civic from Hell" says hi
[Modified by Moosilla, 10:38 AM 7/5/2002]
Old Jul 5, 2002 | 07:51 PM
Banned
Default Re: Looking for SOHC VTEC dyno's (Moosilla)
which cams did you get? who's dave? (where's he from? last name? we met?!?!?)
Old Jul 6, 2002 | 01:41 AM
Moosilla's Avatar
Frank,
I am using the Zex 59300 Cam (and springs).
I do not know if you are aware of this message board .... it is dedicated to the D-series engines ... http://pub34.ezboard.com/bhondadseries There is a couple of guys with some seriuosly strong D-motors
Dave, he drove the red Civic "Hatch from Hell" at OTC ... before his Motor Let go ... I beleive you chatted for a bit.
On an un-related note .... How well made/constructed are the SRR rear camber arms .... MY POS Ingalls Seized up completely after one Canadain Winter Even after being literally "dipped" in Anti-seize, I am not Impressed.
Cheers
[Modified by Moosilla, 2:44 AM 7/6/2002]
Old Jul 6, 2002 | 01:53 AM
Banned
ahh yes, we chatted before the event. at first i was wondering who the heck do i know from canada. coo i'll stop by that board. SRR looks good. i plan to run them in my car. i would have put it in the civic hb before i aligned it last week except even with 600 ft-lbs impact gun i couldn't get the bolts lose. gonna need to soak it with some stuff first. i have the old z.speed rear camber kit with spherical bearings, it is worn and has bout 0.5-1 mm of play so i have a trick real-time dynamic rear camber kit right now as for the adjustment part the z.speed did not seize at all. it is anodized al. the SRR is simliar in that aspect. just hard rubber bushing instead of bearings.
Old Jul 6, 2002 | 10:29 AM
builthatch's Avatar
MiG-21 superfan
...did i read this correctly...did you lose 3 lb/ft and 6 hp with a 2 degree ignition TIMING ADVANCE?
Show15
19
Apr 19, 2010 07:05 PM
socal_93 Si
Apr 10, 2009 09:01 AM
HondaVTEC93
Aug 10, 2004 02:39 PM
Synergy001
Apr 2, 2003 09:38 PM
AshlandSi
13
Nov 9, 2001 07:15 AM
