leaking oil from THAT corner
Old Apr 15, 2006 | 10:24 AM
  #26
Charliehondaman's Avatar
Default Re: leaking oil from THAT corner
A lot of b series motors leak from that corner of the block\head surface, it is in the design of the block and head, main pressure port for oil. An easy fix is take a punch and a hammer and put a bunch of little dots right there in that corner then use coper coat on the gasket and a little thin coat of hi temp gray silicon. know sounds kinda wack but I have been doing that for 7 years and neveer had one leak since. old engine building trick I learned.
Old Apr 16, 2006 | 02:31 AM
  #27
Cole D's Avatar
Default Re: leaking oil from THAT corner (Charliehondaman)
Why don't you try this on Larry's Endyn civic (yes TOO) he uses a thin coat of honda bond on the headgasket and no cooper spray here's the link
http://www.theoldone.com/artic...c.htm
their is a picture describing exactly what I'm talking about
Handyman_1
11
Oct 29, 2008 03:10 PM
dartonh22
Aug 8, 2008 11:44 AM
em1gangsta
Mar 21, 2008 01:35 AM
boomersz
Apr 4, 2007 12:14 PM
Ha Itz
Jan 2, 2007 05:57 PM
