Oil Leak, HELP!
Old 10-28-2008, 02:02 PM
Handyman_1's Avatar
Default Oil Leak, HELP!
I have a b16a2. So I got my head back from the machine shop. I put everything back together. When I started the car it started to POUR out oil, under the distributor side. It looks to me like it is coming from between the head and the block. What do you think it is?
Old 10-28-2008, 02:32 PM
WhiteOnRice's Avatar
Default Re: Oil Leak, HELP! (Handyman_1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Handyman_1 &raquo;</TD></TR><TR><TD CLASS="quote">looks to me like it is coming from between the head and the block. What do you think it is?</TD></TR></TABLE>
The headgasket...
What headgasket are you using?
Old 10-28-2008, 07:36 PM
Handyman_1's Avatar
Default Re: Oil Leak, HELP! (WhiteOnRice)
I am using an OEM Honda gasket that I bought from the dealer.
Old 10-28-2008, 08:11 PM
Well first make sure you know where it's coming from and let us know.
Old 10-28-2008, 08:15 PM
jimmy o.'s Avatar
no headgasket leaks oil check your dizzy o-ring or a bad cam seal pics would help my buddy EK had an oil leak that shevled on the top of the block where it would kinda look like it was coming fom the head but it was a $7 o-ring instead of a $500 top end overhaul
Modified by jimmy o. at 9:26 PM 10/28/2008
Old 10-28-2008, 08:17 PM
mikehawk's Avatar
Default Re: (jimmy o.)
Actually it can come from the head gasket .... a buddy of mine floated his vlaves replaced the springs and bent valves put the HG on the wrong way and when he started it OIL shot all over the place. So it is possible make sure the head gasket is on correctly and make sure you are using the correct head gasket for your motor.
Old 10-28-2008, 08:26 PM
jimmy o.'s Avatar
hmm ive never seen this before someone would have to make some very obvious mistakes for it to happen though
Old 10-28-2008, 08:30 PM
mikehawk's Avatar
I witnessed it .. at 2:30 am at the end of a head rebuild on a obd1 GSR .. quite a sight to see.
Old 10-29-2008, 02:33 PM
Handyman_1's Avatar
Default Re: (mikehawk)
I know I am using the right head gasket. If it was on wrong wouldn't oil leak from all around the head? If you are facing the car it is just leaking out from the left, towards the corner, under the intake side between the head and the block. I would say that it is more of a steady pour instead of a leak. I lost about 2.5 quarts of oil in about 5 seconds. And when i shut the car off it stoped leaking.
Old 10-29-2008, 02:45 PM
1992Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmy o. &raquo;</TD></TR><TR><TD CLASS="quote">no headgasket leaks oil check your dizzy o-ring or a bad cam seal pics would help my buddy EK had an oil leak that shevled on the top of the block where it would kinda look like it was coming fom the head but it was a $7 o-ring instead of a $500 top end overhaul
Modified by jimmy o. at 9:26 PM 10/28/2008</TD></TR></TABLE>
I'm with him on this one. Did you put the valve cover gasket on correctly. IDK, is the Vtec solenoid gasket in there.
Sorry but you have to pretty bad to put the HG on backwards.
Old 10-29-2008, 02:52 PM
yepez1978's Avatar
if might be the seal that goes on the block right by the flywheel u might wana look at that also
Old 10-29-2008, 03:10 PM
.::B00stin2High::.'s Avatar
Default Re: Oil Leak, HELP! (yepez1978)
Check the block.
swizz977
49
11-20-2011 03:09 PM
saemoonyang
12
06-07-2010 02:01 PM
djb97ek
04-11-2010 09:00 PM
jakscivic
05-02-2006 02:26 PM
TheSwift1
11-03-2004 10:34 AM
Quick Reply: Oil Leak, HELP!
