Leak Down Results need some advice.
Old Feb 20, 2006 | 04:33 PM
warwagon's Avatar
Default Leak Down Results need some advice.
2000 ITR 60K
here are the results compared to compression results
1. 220 1-2% warm 5-6% cold
2. 215 1-2% warm 3-4% cold
3. 215 7-8% warm 14-15% cold
4. 205 1-2% warm 3-4% cold
1 quart per 500 miles oil consumption. seemed that all the air escaping was rings.
Just curious if a quick hone and rings would fix my oil eating problem
Old Feb 20, 2006 | 05:15 PM
non-VTEC's Avatar
Default Re: Leak Down Results need some advice. (warwagon)
you might be able to get away with a quick hone and new set of rings.....but you should have the bores measured just in case they are really out of round.
Old Feb 20, 2006 | 08:49 PM
warwagon's Avatar
Default Re: Leak Down Results need some advice. (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">you might be able to get away with a quick hone and new set of rings.....but you should have the bores measured just in case they are really out of round.</TD></TR></TABLE>
yeah my friend has a set of the dial bore gauges or whatever they are called... prolly check them while its apart
gtseviper2
Sep 20, 2010 01:38 PM
esedulerp5tenin
Apr 6, 2010 09:20 AM
warwagon
Mar 1, 2006 09:55 PM
TURBO-JET LUDE
May 7, 2003 10:06 AM
1.8T_EG
Nov 13, 2002 06:59 AM
