leakdown test..burning oil still
Old Sep 20, 2010 | 11:04 AM
gtseviper2's Avatar
Default leakdown test..burning oil still
forge wiseco pistons 85mm
alright I did a leak down test...still burning oil
engine was hot compressor psi the leak down was 40-60...
cylinder
1 12% air from dip stick and oil cap
2 12% air from dip stick and oil cap
3 12% air from dip stick and oil cap
4 12% air from dip stick and oil cap
what you think...
Old Sep 20, 2010 | 11:10 AM
kyden's Avatar
Default Re: leakdown test..burning oil still
a leakdown test won't show bad oil control rings or valve seals.
Old Sep 20, 2010 | 11:25 AM
Hybrid96EK's Avatar
engine was hot compressor psi was 40-60...
cylinder
what you think...
Some will tell you thats "too high", I wouldn't go tearing an engine down for 12% leakage by any means. I think thats pretty good. As mentioned though it won't show you bad oil control rings or stem seals.
Old Sep 20, 2010 | 12:04 PM
gtseviper2's Avatar
Would my a/f be affected from the oil burning
Old Sep 20, 2010 | 12:16 PM
Hybrid96EK's Avatar
I would imagine so. To what extent I would say would depend on the amount of oil you are consuming
Old Sep 20, 2010 | 01:19 PM
blackeg's Avatar
i wouldnt get worried over 12%. once i had a motor that had 80% in the #2 cylinder. it made 350hp and ran for 18k miles and well over 30 track passes.
oil cap and dipstick should indicate through the rings to the crankcase.
just to clarify, your compression check on the motor was 40-60 psi?
Old Sep 20, 2010 | 01:38 PM
gtseviper2's Avatar
oh sorry about that..that was the psi I used for the leak down test
I'm going to do a second test to verify these numbers
Belarus
Oct 17, 2010 04:03 PM
EG94dude
14
Dec 19, 2009 09:06 PM
nsimov
Apr 25, 2006 03:36 PM
IloveNewt
Dec 21, 2003 10:18 AM
jond
Jan 30, 2002 01:17 PM
