late and inconsistent vtec...
Old Aug 12, 2003 | 02:15 PM
untitled's Avatar
Default late and inconsistent vtec...
brand new ls.vtec. it hit at 7000 last when i hit vtec for the first time.my oil feed line is 24inches long. i am thinking that thats it. also i have not gotten around to tapping block for the knock sensor so i am getting code. i hit vtec today and it crossed over a little after 6000. anybody?
Old Aug 12, 2003 | 07:31 PM
PHiZ's Avatar
Default Re: late and inconsistent vtec... (88crx91integra)
disable knock in the ecu, and conceivably if it is a USDM head, the vtec oil pressure sensor won't let vtec kick in with low oil pressure.
You can jump that out, by connecting it to the signal wire on the vtec solenoid, and a common ground.
-PHiZ
Old Aug 13, 2003 | 10:35 AM
untitled's Avatar
Default Re: late and inconsistent vtec... (PHiZ)
its a jdm head and i am using a pr3 obd0 pr3 ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">
-PHiZ</TD></TR></TABLE>
do you have a diagram or anything. go more in depth.
Old Aug 13, 2003 | 11:07 AM
rsbad454's Avatar
i believe you need to run Hondata or Chip that disables the knock sensor signal from being read..........
Old Aug 13, 2003 | 11:55 AM
PHiZ's Avatar
Default Re: late and inconsistent vtec... (rsbad454)
Does hondata suport disabling knock? I thought they didn't.
How to wire bypass vtec oil pressure sensor:
disconnect from oil-pressure sensor, splice it into the vtec solenoid wire.
-PHiZ
Old Aug 13, 2003 | 01:09 PM
untitled's Avatar
doesnt matter anymore... the ****** head gasket is blown. i got on it and there was a little smoke that smelt sweet come out of the drivers side underhood, looked under hood and there was a little bit of moisture on the part of the head gasket that sticks out and you could see moisture on the crack.
Rod.
Mar 16, 2004 11:07 PM
ViVaLaLude00
12
Mar 8, 2004 06:39 AM
ITR1071
Jan 2, 2003 04:32 PM
r7
12
Jun 13, 2002 10:21 AM
HybridRexy
May 5, 2002 08:19 PM
