What is this plug on B16 head, search no luck
What is this plug on B16 head, search no luck, b16 owners take a look
My friend told me its a vtec lock sensor something like that. Is he right? He said I have to wire it into the ecu. I have a p28 ecu and where do I wire it into on the ecu? Its the sensor that looks like it is half way in there
Modified by redturbocivic at 11:05 PM 3/16/2004
Re: What is this plug on B16 head, search no luck (redturbocivic)
I think thats the vtec oil pressure sensor. I dont know the pinouts but there should be a wire or two for it coming out of the ecu.
Re: What is this plug on B16 head, search no luck (Cruiser G)
This is goign to be ls vtec turbo. So far I have the vtec wire plugged in & the oil pressure. Still cant figure out what that is. I am working off a ls harness with a p28. Basically I am wiring for vtec in a non vtec car
some1 answer this. i thought my ls had the same sensor. i doubt its anything vtec related. i think the vtec oil pres. sensor is right net to the vtec solonoid.
vtec pressure goes to D6 on P28.
just double checked, thats the right one.
Duh, didnt even first notice. That sensor is coolant temp.
The Vtec Pressure is part of the vtec solenoid housing.
Okay, TW. One pin goes to D13, the other to ground.
Modified by leed at 7:31 AM 3/17/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">Basically my ls harness should probably have a plug that plugs in that right?</TD></TR></TABLE>
Yes, your harness will have a plug for it. From the looks of it, it looks like your head is missing the Coolant temp guage sending unit. You can get it off of your LS head if you still have it. Its the hole located to the left of the coolant line.
92accordh22a
12-16-2006 07:21 AM
DJ_SaNdOz
21
01-19-2005 07:49 AM
