vtec not engaging
Re: vtec not engaging (civic2nr97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic2nr97 »</TD></TR><TR><TD CLASS="quote">i dont have a knock sensor hooked up in my car will this cause vtec not to engage?</TD></TR></TABLE>
If you are suppose to have a knock sensor and your ECU is looking for one and not finding one and you are throwing a Knock Sensor code then yes it will not engage.
Re: vtec not engaging (Mr Milano)
no i had a d16y7... i put a z6 head on there an i have to install a knock senor... but im throwing a few other cels also like the IACV i think i need to reaplce that an then im throwing a emissions cell.... code 91 i believe
Re: vtec not engaging (ekb18cCivic)
yea it is wired up unless it isnt wired up correctly... to clean out the iacv what do i use to clean it like thottle body cleaner or what not
Your ecu may just be going into safe mode after the swap. I ran without 02temp sensor fora few months and then the ecu just went into safe mode and gave me a 7000 rev limit and no vtec. It also does that when it's cold until the motor warms up.
