KYB AGX and Tom's coilover sleeves...
Old 04-10-2003, 04:40 AM
b17gsr's Avatar
Default KYB AGX and Tom's coilover sleeves...
I'm having some fun with the front coilover sleeves from a Tom Motorsport kit going on a 97 Civic coupe.
Should I grind a bit of metal off the strut so that the sleeve will sit properly on the strut? And why aren't both indentations the same? Both front struts have the same part number.
TIA.
Old 04-10-2003, 08:54 AM
dfoxengr's Avatar
u dont need to change anything...
Old 04-10-2003, 09:15 AM
psi420's Avatar
Default Re: (hybridvteceg)
Turn the cup upside down, or you will sheer the coil over sleeve eventually.
Old 04-10-2003, 10:02 AM
b17gsr's Avatar
Default Re: (psi420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi420 &raquo;</TD></TR><TR><TD CLASS="quote">Turn the cup upside down, or you will sheer the coil over sleeve eventually.</TD></TR></TABLE>
Can't do that, the other end has 3 allen screws to keep the sleeve in place.
Old 04-10-2003, 10:19 AM
psi420's Avatar
Default Re: (b17gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b17gsr &raquo;</TD></TR><TR><TD CLASS="quote">
Can't do that, the other end has 3 allen screws to keep the sleeve in place.</TD></TR></TABLE>
I hope they hold it in position for you.
itsalmostfrieday
15
03-30-2007 06:00 AM
illagee
11-03-2005 09:35 PM
SleepnCiViC
07-07-2004 07:32 PM
beachboyy
05-29-2003 02:39 PM
FBP Si 2000
04-14-2003 07:24 PM
Quick Reply: KYB AGX and Tom's coilover sleeves...
