KYB AGX and Tom's coilover sleeves...
I'm having some fun with the front coilover sleeves from a Tom Motorsport kit going on a 97 Civic coupe.
Should I grind a bit of metal off the strut so that the sleeve will sit properly on the strut? And why aren't both indentations the same? Both front struts have the same part number. http://www.va3erc.ca/mr/KYB_AGX_and_Toms.jpg TIA. |
u dont need to change anything...
Re: (hybridvteceg)
Turn the cup upside down, or you will sheer the coil over sleeve eventually.
Re: (psi420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi420 »</TD></TR><TR><TD CLASS="quote">Turn the cup upside down, or you will sheer the coil over sleeve eventually.</TD></TR></TABLE>
Can't do that, the other end has 3 allen screws to keep the sleeve in place. |
Re: (b17gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b17gsr »</TD></TR><TR><TD CLASS="quote">
Can't do that, the other end has 3 allen screws to keep the sleeve in place.</TD></TR></TABLE> I hope they hold it in position for you. |
