How could you freeze a shock?
Old May 10, 2004 | 09:24 PM
kevinoneill's Avatar
Default How could you freeze a shock?
my front 2 koni yellows are frozen/stuck in place. they don't budge what so ever. it happened over the past few days while i've been installing my ingalls camber kit on my crx and re-adjusting the ride height (ground control).
could jacking the car up too high pull the shock all the way and and get stuck or something? i'm completely stumped and very frustrated as to why they've frozen. they've frozen while sitting in the garage...not even driven it. and my front right toe is wayyyyyy out. can't figure that one out either.
i need to get this fixed asap. help suggestions, anything is welcome.
Old May 11, 2004 | 07:50 AM
Ekasey's Avatar
Default Re: How could you freeze a shock? (issues4)
i dont know how but the shocks shoudlnt freeze by pulling the shock too far they should move acorss the full range of travel with no restriction. Yuor front toe being way out could just be out of asjustment or the tie rod might be bent
Old May 11, 2004 | 12:30 PM
Default Re: How could you freeze a shock? (eLusive ek4)
tie rod bent? god don't say that. i looked okay yesterday.
the only i've thought of is maybe the camber was too far out and put pressure on the shock....?
Old May 11, 2004 | 12:37 PM
Ekasey's Avatar
mmmm i dont think that would casue it, i would call koni regarding the shock casue i have neevr heard of or seen that. what happens when you lower the car off the jack?
Old May 12, 2004 | 05:38 PM
well apparently it was the camber kit killing the shocks. i reduced the engalls to its lowest setting and the shocks are working again. kinda odd i know...but perphaps too much camber was causing them to push against something. fyi: engalls 1.25 - 3.00 set to 1.25. It fixed the bad toe i was having on the front right aswell. SWEET!
Old May 13, 2004 | 07:12 AM
Ekasey's Avatar
good good, yeah i ahve never known a camber kit to put that muhc side loading on a shock to freeze it but who knows right. A tip also when your aligning your car is that you adjust toe camber then caster int hat order if its clsoe to specs because toe usually will bring the camber clsoe to specs when set itself and camber can bring caster close
Old May 13, 2004 | 12:25 PM
good to know. i'm getting it aligned tom. morning.
Old May 13, 2004 | 04:28 PM
dfoxengr's Avatar
fist off, we dont have any sort of shocks as our suspension on hondas.
theyre called struts
Old May 13, 2004 | 05:01 PM
Default Re: How could you freeze a shock? (hybridvteceg)
first of? did you have a "and secondly" you didn't want to say?
Old May 13, 2004 | 05:11 PM
dfoxengr's Avatar
nope, i am a stickler for the proper terms though
hcivic99
Suspension & Brakes
11
Aug 1, 2006 10:04 AM
RacerTim
May 6, 2006 01:05 AM
insomniac791
Jun 23, 2004 05:39 PM
nikolai.
Mar 8, 2004 07:34 AM
