knocking tranny
Old 04-02-2006, 11:39 PM
JDMtype Eg6's Avatar
Default knocking tranny
while my car is idling you can hear this knocking noise, and as i rev the motor the knocking gets faster; the noise also goes away once i press all the way down on the clutch. Can anyone identify this noise or identify the problem? thanks
Old 04-03-2006, 09:19 AM
Knockturnalryder's Avatar
Default Re: knocking tranny (JDMtype Eg6)
that could be your piolite bering that went out on mine and same thing as urs push in the clutch ...goes away as soon as u let it out comes right back
Old 04-03-2006, 09:48 AM
JDMC-Kamel's Avatar
Default Re: knocking tranny (Knockturnalryder)
that or your clutch release bearing
Old 04-03-2006, 05:29 PM
Default Re: knocking tranny (JDMC-Kamel)
thanks
Old 04-04-2006, 11:31 AM
EnzoSpeed's Avatar
What does it mean if you replaced both bearings and you still have the same problem?
Old 04-04-2006, 06:54 PM
D Tranny Guru
Mista Bone's Avatar
Default Re: knocking tranny (EnzoSpeed)
how bad is the knocking???????
with all gears turning at once, there will ALWAYS be some clashing noise.
Just like that tick EVERY Honda has, some people think it is the valves needing adjusted when it is only the injectors cycling at idle.
Old 04-04-2006, 08:55 PM
EnzoSpeed's Avatar
Default Re: knocking tranny (Mista Bone)
My tranny makes horrible ticking and clicking noises when the clutch is out. New pilot and throwout bearings.
I think something is busted inside the tranny but I don't want to take it apart.
DeNNis.
03-23-2008 05:06 AM
jimbrown
07-17-2007 12:35 PM
JDMtype Eg6
05-29-2006 03:45 AM
4gnhatch
06-24-2005 06:53 PM
garados
02-03-2003 11:08 AM
Quick Reply: knocking tranny
