knocking tranny
Old Apr 2, 2006 | 11:39 PM
JDMtype Eg6's Avatar
Default knocking tranny
while my car is idling you can hear this knocking noise, and as i rev the motor the knocking gets faster; the noise also goes away once i press all the way down on the clutch. Can anyone identify this noise or identify the problem? thanks
Old Apr 3, 2006 | 09:19 AM
Knockturnalryder's Avatar
Default Re: knocking tranny (JDMtype Eg6)
that could be your piolite bering that went out on mine and same thing as urs push in the clutch ...goes away as soon as u let it out comes right back
Old Apr 3, 2006 | 09:48 AM
JDMC-Kamel's Avatar
Default Re: knocking tranny (Knockturnalryder)
that or your clutch release bearing
Old Apr 3, 2006 | 05:29 PM
Default Re: knocking tranny (JDMC-Kamel)
thanks
Old Apr 4, 2006 | 11:31 AM
EnzoSpeed's Avatar
What does it mean if you replaced both bearings and you still have the same problem?
Old Apr 4, 2006 | 06:54 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: knocking tranny (EnzoSpeed)
how bad is the knocking???????
with all gears turning at once, there will ALWAYS be some clashing noise.
Just like that tick EVERY Honda has, some people think it is the valves needing adjusted when it is only the injectors cycling at idle.
Old Apr 4, 2006 | 08:55 PM
EnzoSpeed's Avatar
Default Re: knocking tranny (Mista Bone)
My tranny makes horrible ticking and clicking noises when the clutch is out. New pilot and throwout bearings.
I think something is busted inside the tranny but I don't want to take it apart.
DeNNis.
Mar 23, 2008 05:06 AM
jimbrown
Jul 17, 2007 12:35 PM
JDMtype Eg6
May 29, 2006 03:45 AM
4gnhatch
Jun 24, 2005 06:53 PM
garados
Feb 3, 2003 11:08 AM
