Knock Sensor Code, problems?
Old Apr 21, 2004 | 12:24 PM
Defi4nce's Avatar
Default Knock Sensor Code, problems?
IF the car is giving a KS cel. Will the car go into limp mode, retard timming, add fuel or anything like that?
The motor is an LS/vtec. Ecu is p72 or p30 (have both). Short of getting a chipped ecu is there a way other than adding a KS to make the code go away?
Thanks.
Old Apr 21, 2004 | 01:11 PM
ensracer's Avatar
Default Re: Knock Sensor Code, problems? (Defi4nce)
i believe that it is code 41 but the ls does not come with knock sensor so what you can do is weld or jb weld a nut big enough for the knock sensor and just place it next to the number 2 cylinder and just run the wire to the ecu...i forget what pin sorry
Old Apr 21, 2004 | 02:38 PM
Defi4nce's Avatar
Default Re: Knock Sensor Code, problems? (eduardo)
I dont want to do that.
What I really want to know is what adverse effects will the KS code cause?
Old Apr 21, 2004 | 02:51 PM
ensracer's Avatar
nothing....by the time the ks sends the signal that there is detonation your engine will have already suffered the damage.
Old Apr 22, 2004 | 08:34 AM
Defi4nce's Avatar
What I want to know is. If the there is no Knock sensor (ls block) and there is one in the ECU (p30).
Will the car go into limp mode? Retard timming? or Add fuel? Or a combination of all?
Old Apr 22, 2004 | 01:11 PM
Defi4nce's Avatar
ttt
Old Apr 25, 2004 | 07:48 AM
chameleon's Avatar
bump, would like to know also.
Old Apr 25, 2004 | 10:01 AM
doublejz's Avatar
Default Re: Knock Sensor Code, problems? (chameleon)
if the ecu looks for it you'll just have a CEL. No limp mode or anything. I have been running mine without KS for like 5 months now. It is kinda nice, the CEL doesnt come on until it warms up so I wait to beat on my car, until I see the CEL Some cars/ecus it will not allow vtec to engauge but I'm not having that problem
R_Machine
Sep 10, 2005 11:59 PM
TRhatchCRAP
10
Aug 10, 2003 11:52 AM
hondaspeder
Jun 19, 2003 09:21 PM
CRexcellence
Apr 29, 2003 09:05 AM
jdmciviceg
Jun 9, 2002 07:56 PM
