knock sensor
Old Jun 18, 2003 | 04:26 PM
Ivan's Avatar
senior gold member
Default knock sensor
what would be the best way to put a knock sensor on a b18b? it doesn't have a spot for it and I need it.
Old Jun 18, 2003 | 08:13 PM
intekragsr's Avatar
Default Re: knock sensor (Ivan)
you need a 12X1.25 tap. I have a knock sensor for sale of your interested.
Old Jun 18, 2003 | 08:51 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">what would be the best way to put a knock sensor on a b18b? it doesn't have a spot for it and I need it. </TD></TR></TABLE>
Did you see VTECVillain's post in the Hybrid forum?
Old Jun 18, 2003 | 08:53 PM
Ivan's Avatar
senior gold member
Default Re: knock sensor (poison)
yup. thats what Ima do. actually since its in the car. I did a search on it and this guy had an idea of welding a nut with the correct thread and pitch on top the the bolt that goes thru the alternator bracket. Ima do it that way since theres like no room.
Old Jun 18, 2003 | 09:00 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">yup. thats what Ima do. actually since its in the car. I did a search on it and this guy had an idea of welding a nut with the correct thread and pitch on top the the bolt that goes thru the alternator bracket. Ima do it that way since theres like no room.</TD></TR></TABLE>
ya, it's a bitch, alone just to replace it with it already installed.
I had to replace my knock sensor and wasn't much room to work with. Of course, it's an h22 into a civic, so no room anywhere
Old Jun 18, 2003 | 09:01 PM
intekragsr's Avatar
i installed a knock sensor on my ls block in less than a minute with the tap. I dont see any other efficent way to do it.
Old Jul 3, 2003 | 05:33 PM
D A 9's Avatar
Default Re: knock sensor (intekragsr)
where did you install it?
Old Jul 3, 2003 | 06:25 PM
Ivan's Avatar
senior gold member
Default Re: knock sensor (Bodykitless)
I had a spare nut from a motor mount and welded it to one of the alternator bracket bolts. then tighten the bolt back to the bracket and then installed the knock sensor. pretty easy and it works fine heres a pic courtesy of c-speedracing. mine came out the same way except I didn't drill and tap.
DelSol-B-18
20
Mar 5, 2013 07:21 PM
95BoostedEJ1
10
Nov 23, 2007 10:51 AM
integg93
Aug 3, 2006 01:17 PM
drewek-9
12
May 13, 2004 08:41 AM
Ivan
Jun 18, 2003 08:00 PM
