Kill Switch Q. Need a relay?
Old Sep 29, 2001 | 07:12 PM
Christine's Avatar
New User
Default Kill Switch Q. Need a relay?
I posted this in the Security/Audio section, but with no responses. Thought I'd try here:
I've seen a couple of posts about installing an ignition kill and a fuel pump kill. Some have recommend using a relay, while others say to just use a switch.
Questions:
Is a relay necessary or will a swith suffice?
What would the current rating on the switch need to be?
Also, will a closed relay drain a battery if you park for a [long] while?
thanks
Old Sep 29, 2001 | 07:43 PM
GSRMatt's Avatar
25 Year Member
Default Re: Kill Switch Q. Need a relay? (Christine)
The answers to all your questions depend on which wire you choose to cut for the kill switch. Pick a wire that triggers a relay and you can just use a switch, there won't be a large current draw.
Old Sep 30, 2001 | 01:47 AM
dj_fixx's Avatar
New User
I have a simple push button latching relay fuel pump kill.
non detailed how to (tehehe)
make sure u have the proper tools:crimpers, wire strippers, multi meter, connectors, relay, push button alarm switch.
pull up ur back seat
see the aluminium cover, with wires running out of it
check which wires are energized with the car running (not just on)
cut one (blk wire white stripe, mabye... i'll ck tomorrow)
if the car stops dies within 10 sec you got it(remember the fuel rail has to lose pressure)
connect speaker wire to each side, run to switch, relay, what ever
For relay or more questions just ask and I'll try to respond as soon as possible
Old Sep 30, 2001 | 03:23 PM
Christine's Avatar
New User
Default Re: Kill Switch Q. Need a relay? (GSRMatt)
Thanks to both of you. I appreciate the help.
Old Oct 1, 2001 | 08:38 AM
92sleepR's Avatar
New User
I put a switch on the injector relay and haven't had a problem. Kills the car deader than dead and is virtually impossible to bypass.
Mike
WetCoastRacing
May 20, 2017 02:28 AM
dgdarien
Audio / Security / Video
Apr 12, 2009 12:03 PM
jdmjin
10
Sep 15, 2008 04:47 AM
GS8HFL21
Nov 9, 2005 06:56 AM
fred92htch
Aug 15, 2002 12:53 PM
