JDM d15d
Old Feb 12, 2007 | 07:14 PM
92 hatch d15b JDM's Avatar
Default JDM d15d
I just put a jdm d15b motor in my 92 hatch it was non vtec d15b7 the car is running really good but i do not think vtec is working i am also throwing a check engine light on i ran the code to see what is was and it came back code 21 vtec spool selanoid will this make vtec not work and how can i fix it
Old Feb 12, 2007 | 09:05 PM
Default Re: JDM d15d (92 hatch d15b JDM)
is this something that know one knows anything about cause everytime i post my problem i get no answer i thought this was a fourm to get help and it seems to me this site is bs...........
Old Feb 12, 2007 | 10:14 PM
morningstar's Avatar
How about searching before jumping to the assumption that "this site is bs" the reason youre throwing the code is because you probably didnt wire up vtec correctly
Old Feb 13, 2007 | 10:31 AM
Default Re: JDM d15d (morningstar)
Well that does me no good cause thats not even for my setupi have a d15b this is for gsr and b16s
Old Feb 13, 2007 | 11:40 AM
EJgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 hatch d15b JDM &raquo;</TD></TR><TR><TD CLASS="quote">Well that does me no good cause thats not even for my setupi have a d15b this is for gsr and b16s</TD></TR></TABLE>
lol ITS THE SAME CONCEPT!
Old Feb 13, 2007 | 12:46 PM
Default Re: JDM d15d (EJgsr)
i am using a p28 so i herd that there is no other wiring that needs to be done than the a4 and d6 i have all the wiring right and still the code 21 will not go away and i tested the vtec with +and- power and it clicks
Old Feb 13, 2007 | 02:18 PM
HondaPartsHero's Avatar
Technical Hero
did you add the pressure switch, because generally the D15B's didn't come with it,
Old Feb 13, 2007 | 02:20 PM
Some one told me to wire the pressure switch and the selanoid together to a4 and then ground d6 to i tried it other than the way its is supposed to be witch i had it and my check engine light went off for the first time i took it for a ride and vtec was def working and still no light but after driving for like 15mins the light came back on and no vtec should i keep it wired like that or should i put it back the way i had it
Old Feb 13, 2007 | 03:42 PM
EJgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 hatch d15b JDM &raquo;</TD></TR><TR><TD CLASS="quote">is this something that know one knows anything about cause everytime i post my problem i get no answer i thought this was a fourm to get help and it seems to me this site is bs........... </TD></TR></TABLE>
GTFO then. make your own web site.
Old Feb 13, 2007 | 09:32 PM
Jonknee's Avatar
quit whining and search for yourself
Old Feb 14, 2007 | 09:42 AM
Default Re: JDM d15d (Jonknee)
I think that this site is fucken gay as hell nobody gives the right info you are told to do ten different things and none of them work plus i ask for help and people start talking **** how about all you grown men stay off the gay **** sites and maybe help out (****)...expletive all ya niggs and if any of you bitches got something to say i am from nj come see me and what the expletive is this bullshit about only beeing able to post 5 post a day tell me thats to gay THIS SITE SUCKS MONKEY *****.............
Old Feb 14, 2007 | 04:50 PM
Jonknee's Avatar
gtfo crybaby
wreckonize
Jun 10, 2009 07:39 PM
ghettoSi
Jan 11, 2008 11:39 PM
D-Rob
Jan 12, 2006 06:17 PM
preludeblue
Dec 18, 2005 02:35 PM
wfo
Feb 25, 2005 02:21 PM
