ITR 5 lug conversion
Old Feb 15, 2006 | 10:11 PM
fabworxs's Avatar
Default ITR 5 lug conversion
Not sure where to post this but figured it should be a no brainer for HONDA-TECH!
Want to confirm that the 94-97 USDM Integra rear lower control arms will work on a 5 lug conversion??
Help Please!
Old Feb 16, 2006 | 03:58 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: ITR 5 lug conversion (fabworxs)
In theory they should work... i think the only difference is the shock mount.
But if your buying the whole ITR suspension, then why not just use the ITR LCA's?
Old Feb 17, 2006 | 01:16 PM
fabworxs's Avatar
Default Re: ITR 5 lug conversion (JDM_Ej)
ttt
PLEASE
Old Feb 17, 2006 | 04:17 PM
sc4dr's Avatar
The control arms and struts shouldnt matter, because the only thing you should be replacing is the knuckle, hub and bearing, rotor and caliper...correct?
kcjohnnyboy
Suspension & Brakes
Jun 21, 2005 10:22 PM
go2sleep
Apr 14, 2005 12:54 PM
campbuds
Jul 27, 2004 12:18 PM
subzero_SiR
Aug 11, 2003 04:39 PM
Scorpaznatica
May 30, 2002 01:52 PM
