Integra Automatic Transmission Slipping Question
Old Mar 15, 2003 | 10:58 PM
bluballer's Avatar
Default Integra Automatic Transmission Slipping Question
I have a 90 Integra GS with 135,000 miles on an auto tranny that started having a weird problem. When Its first started (cold) I can put it in drive and it functions as normal. When it warms up to operating temperature It suddenly drops out like the car is in neutral (slipping). Now if I cut the car completely off and start it up again after a short while it runs again and the cycle repeats. I talked to someone and they said what might be happening is the screen gets clogged with trash when it warms up preventing flowand and when I cut it off it settles. Is there a remedy for this short of a new tranny? Can this type of trannny be flushed? any additives help? anyone experienced this before? What was your resolution?Any help will be appreciated. P.S. I bought this car and didnt know it had this problem
Old Mar 16, 2003 | 01:37 AM
RABBIT9's Avatar
Default Re: Integra Automatic Transmission Slipping Question (bluballer)
I had the same problem; flushing won't help at all.
It's time for a rebuild or MT swap.
Old Mar 16, 2003 | 10:40 AM
bluballer's Avatar
Default Re: Integra Automatic Transmission Slipping Question (RABBIT9)
LOL Thanks Rabbit9, I was hoping not to hear that answer. Curious though, how many miles did you have on yours when this happened, and what was the true cause?
Old Mar 16, 2003 | 10:59 AM
Chiovnidca's Avatar
I used to see that alot on Accords. It turned out to be the lockup clutch lining in the torque converter breaking apart. The only way I know to repair them is to replace the converter, and dissasemble the trans to clean it.
Old Mar 16, 2003 | 11:16 AM
bluballer's Avatar
Default Re: Integra Automatic Transmission Slipping Question (D16Chiovnidca)
WOW You want tech you get TECH!!!! I love this board!!!! Ok whose got the cutaway so I can see visually what is happening...LOL I was gonna sell the car but I'mma keep the car because of you'se guys....LOL Thanks!!! 2 thumbs-up people
Old Mar 17, 2003 | 03:37 PM
RABBIT9's Avatar
The odometer was right around 190K. It probably would have lasted awhile longer, but I started rebuilding everything on the car and added more HP/TQ.
Old Mar 17, 2003 | 06:02 PM
altoid's Avatar
yeah happened with lots of accords, clogged the filter and f'ed everything up. Easy fix if you know what you're doing, and i know honda put an extended warranty on the accord trannies that did that, so i would go look up that info
96ls4dr
Jan 15, 2008 11:38 PM
one bad dx
Sep 6, 2007 01:57 PM
tjh2a
May 26, 2006 11:12 AM
allmotor92civic
Feb 20, 2005 06:10 PM
