Injector tech
Well I just started researching injectors and I can't seem to find to much about them. I know the two main ones are saturated and peak and hold. Which of these two need a resistor box? I've been looking into RC injectors and I have someone offering me 440cc's for $70 a piece brand new(good price??) which i plan on using to run 7psi at first with Apexi S-AFC. Ive heard that you can't lean out the fuel as well with bigger injectors and a piggyback. Is this true for 440cc's? What hp do 440's top out at? What are the pros and cons of both kinds of injectors? Lastly what are clips? Are there a difference between OBDI and OBDII injectors? Sorry if this has been asked a million times.
Thanks for all the info
Stewart
Stewart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrestler121 »</TD></TR><TR><TD CLASS="quote">Well I just started researching injectors and I can't seem to find to much about them. I know the two main ones are saturated and peak and hold. Which of these two need a resistor box? I've been looking into RC injectors and I have someone offering me 440cc's for $70 a piece brand new(good price??) which i plan on using to run 7psi at first with Apexi S-AFC. Ive heard that you can't lean out the fuel as well with bigger injectors and a piggyback. Is this true for 440cc's? What hp do 440's top out at? What are the pros and cons of both kinds of injectors? Lastly what are clips? Are there a difference between OBDI and OBDII injectors? Sorry if this has been asked a million times.
Stewart
The peak/hold injectors require a resistor box...the 440cc's should be fine for your setup....the safc will be a good tuning tool when it comes to leaning out the fuel mixture....IMO safc's and vafc's can lean out mixtures much better than they can add fuel..and yes that is a very good deal for brand new rc 440cc injectors for your car..good luck
Stewart
I'm selling some brand new 409cc injectors w/ clips right now. Take a peak, they're located here.
https://honda-tech.com/zerothread?id=644488
stockhatch91
Nov 22, 2004 03:59 PM
