injector leak.
Old Mar 10, 2007 | 10:38 PM
iwantspeed's Avatar
Default injector leak.
ive been noticeing lately that around the bottom hole under 1 injector on my skunk2 intake manifold there has been gasoline. and brown residew from the fuel burning on the intake mani..
so i went to honda and got a injector seal kit and replaced them all, put stuff back together and tested... still a leak from the same upper injector seal.. the fuel is literally running down the injector onto the manifold. do u think the aem fuel rail is messed up? i do not have a stock one to test or i would... and u know how the back of the fuel rail has 3 bolts holding it down... well 2 of the holes are pretty stripped. but the bolts still hold down tight enough so that i can shake the fuel rail and not have it move at all.
thanks.
Old Mar 11, 2007 | 10:20 AM
iwantspeed's Avatar
Default Re: injector leak. (iwantspeed)
did i not post this in the right forum?
Old Mar 11, 2007 | 11:42 AM
b16nonoy's Avatar
the 2 bolt thing is your problem.
Old Mar 11, 2007 | 02:03 PM
iwantspeed's Avatar
Default Re: injector leak. (b16nonoy)
soa new intake manifold. thanks.
Old Oct 24, 2007 | 12:34 PM
redsi89's Avatar
i'm having the same problem i have a b16 in my crx and an aem fuel rail and the number one injector is leaking like crazy i replaced the o-rings as well and i have no fastener issues. i wondered if i want speed fixed his problem and how.
Old Dec 20, 2007 | 08:58 PM
iwantspeed's Avatar
Default Re: injector leak. (redsi89)
nope still havnt fixed it. lol
Old Dec 20, 2007 | 09:32 PM
vteczone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16nonoy &raquo;</TD></TR><TR><TD CLASS="quote">the 2 bolt thing is your problem.</TD></TR></TABLE>
yeah..fix the bolts and see what happen.it shouldnt cost that much.
Old Dec 21, 2007 | 03:34 AM
Flashmn's Avatar
Default Re: injector leak. (vteczone)
might also be a faulty o-ring
Old Dec 21, 2007 | 07:21 PM
iwantspeed's Avatar
Default Re: injector leak. (Flashmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn &raquo;</TD></TR><TR><TD CLASS="quote">might also be a faulty o-ring</TD></TR></TABLE>
i replaced the oring with a honda oem o ring.
Old Dec 22, 2007 | 06:07 AM
Flashmn's Avatar
Doesnt mean it didnt get damaged while putting the injector in, you did lube the o-ring prior to installation?
Old Dec 22, 2007 | 07:27 AM
iwantspeed's Avatar
couldnt think of propper lube to use.. what should i use? like oil or sumthing thick? also i was told that the screens on the top of the injector get clogged up with junk and cause this to happen.
Old Dec 22, 2007 | 08:35 AM
Flashmn's Avatar
The screen on top has nothign to do with the injector leaking, it only prevents juice from coming through the injector. If its clogged it will pass the injector.
I used some spray oil, just to get it nice and slick.
Old Dec 22, 2007 | 09:29 AM
atec's Avatar
Use "dry lube(spay)", in fact a small amount of hand soap will do the job an rubber O rings.
be careful not to use oil or gasoline, the O-rings will/can expand and you will have trouble mounting your rail.
Old Dec 22, 2007 | 10:13 AM
Flashmn's Avatar
Default Re: injector leak. (atec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">be careful not to use oil or gasoline, the O-rings will/can expand and you will have trouble mounting your rail. </TD></TR></TABLE>
Oil isnt that bad, NBR hydraulic o-rings withstand oils. Gasoline makes them expand, but it doesnt happen instantly, so no problem there.
Old Dec 22, 2007 | 01:04 PM
atec's Avatar
The Orings is supposed to expand when applyed with gasoline, but All Im saying is dont use any petrolated fluids prior assembly, if they expand while you are mounting the rail you will have increased your chance of damaging your O-rings.
I dont care about any hydraulic what so ever, the only thing Im saying that is within topic is how to mount them the easyest way with the propper lubricant.
I got a honda
Dec 15, 2005 06:14 PM
m R g S r
Oct 12, 2004 08:48 PM
Cowboy
Mar 18, 2004 05:56 PM
Louie_EM1
12
Feb 29, 2004 09:34 AM
jabroni95gsr
Apr 15, 2003 05:05 AM
