idle problems
Old Feb 14, 2004 | 11:07 PM
rtiadnoh's Avatar
Default idle problems
i have a idle problems with my car. it goes from 750 to 1500 every other second when im at a stop. all sensors and everything is connected. i need help. sorry im new at all this.
Old Feb 15, 2004 | 12:41 PM
RedlinedVTEC's Avatar
Default Re: idle problems (rtiadnoh)
Sounds like a vacuum leak. Spray carb cleaner around the intake manifold mating surface and throttle body mating sruface while the car is running. If while spraying the motor suddenly raises revs up, you've found your leak. If you can't find and gasket leaks, look at your vacuum hoses, one could be loose or cracked.
chope045
Oct 24, 2011 04:12 PM
erichackett
10
Jul 27, 2010 06:43 PM
JDMCivic16
Jun 8, 2009 02:12 PM
95dc2teg
Sep 11, 2007 05:49 PM
Vp Special K
26
Nov 9, 2003 10:24 AM
