idle problem damnit
Old Jun 3, 2005 | 12:16 PM
NumberB's Avatar
Default idle problem damnit
my gsr is idling from about 1- 2k. i changed the fitv which i was told needed to be replaced but it still idles very rough when its around 1k and it jumps around? is this distributor or throttle cable or iacv problem? i dont wanna buy stuff if they arent broken and the iacv cost like 200 bucks. could anyone give some more input into this? thanks
Old Jun 3, 2005 | 08:59 PM
NumberB's Avatar
Default Re: idle problem damnit (milb16a)
bump
Old Jun 3, 2005 | 09:03 PM
korean_teg's Avatar
any mods?
Old Jun 4, 2005 | 01:32 AM
NumberB's Avatar
has a skunk2 im and type r throttle body and i/e/h/ flywheel and clutch
Old Jun 4, 2005 | 01:43 AM
WhiteGSR95's Avatar
could be 1 of several things.
try checking for a vacuum leak, iacv, possible bad map.,or ect
just read that u wanted to be sure about what was wrong, the only was to be sure is to hook a scan tool up to the car
Old Jun 4, 2005 | 03:25 AM
option2dc2's Avatar
Default Re: (WhiteGSR95)
Try your TPS SENSOR, or see if you have a leak around your throttle body or intake manifold, i had the same problem with the idle and finally figured out it was the a leak from the throttle body
Old Jun 7, 2005 | 02:26 AM
NumberB's Avatar
Default Re: (option2dc2)
well put a new gasket on the throttle body and now im thinking of checking the iacv? anyone know what to clean these with? all i got is superclean right now but i was thinking of trying to clean it to see if that helps. anyone know if thats alright to clean it with?
Kustom X
Apr 3, 2012 07:21 PM
Dannyx321
Oct 17, 2011 05:40 PM
DO/\/\O
Jul 26, 2011 01:44 AM
feriotypeR
Oct 10, 2009 03:58 AM
handa
19
May 24, 2005 03:43 AM
