Idle Problem !!!! PLEASE HELP!!!
Ok ladies and Gents i have a 1990 Acura integra DA w a jdm b20 swap and it has a pretty bad idle, it doesnt idle to high or anything but it fluctuates up and down ( its worse when its still cold it will idle all the way up to 3500 ) but it doesnt do it as bad when it warms up
things ive done to try and correct the problem
1. Replaced the TPS sensor and throttle body
2. Checked every single vaccum line and they're all fine
3. Took off IAC valve and cleaned it thoroughly twice
4. ive even checked my coolant to make sure there wasnt any air bubbles in my coolant cause ive heard that would do it!!
What else is left to do ? PLEASE ANY HELP WOULD BE GREATLY APPRECIATED!!!!
I had this same problem a few weeks ago, I tried everything, I found the problem by spraying brake cleaner around the intake maninfold while the car was running and it killed the engine, So I had a bad manifold gasket
any electrical diagnostics with your iavc? tps do not have to be set unless they've been taken off before. pay more attention right now to your iacv for correct voltages and cleanliness and throttlebody gasket for leaks.
Make sure the coolant system is bled really well. Make sure you didn't connect the IAC with the plug for the IAT and vice versa. Seeing as it gets better when warmed up could be a sign of intake leak that closes up when hot allthough the engine will run richer when cold causing higher idle.
my cousins honda was acting like that too and it turned out to be his fuel pump. his is the 96b16sprayin i put a post earlier about it and when he got it checked out that was the problem. not sure about yours but something to consider
Some shop will do a scan for a vehicle for a cheap prize just to get the fault code and fix it by your self, this purpose is to save time or stop guessing for fixing problem. I'd read it from some of advertise or do a search.
crxguy406
Sep 10, 2015 03:56 AM
homeskillet
Jan 13, 2005 05:04 PM
