idle oil pressure
Old 07-18-2003, 01:08 PM
Audipwr1's Avatar
Default idle oil pressure
my b18b at idle is having a static 60psi oil press. That seems huge!
tried two different grounds with same pressure results
unit is a vdo with vdo sender
electrical
thanks
Old 07-18-2003, 01:09 PM
.RJ
.RJ's Avatar
Default Re: idle oil pressure (Audipwr1)
seems high... whats cruising oil pressure?
Old 07-18-2003, 01:16 PM
Audipwr1's Avatar
Default Re: idle oil pressure (.RJ)
havent taken her out yet made me nervious to see that high of a number
im gonna go drive it now and get some info on that
Old 07-18-2003, 01:18 PM
SIRX's Avatar
was your motor just rebuilt? I've seen new motor run about 45-50 psi during break in at an Idle but, 60 should be around cruising rpm. If it was just rebuilt maybe the clearances are really tight. Just a thought
Old 07-18-2003, 01:22 PM
Audipwr1's Avatar
RJ thanks
warm up pressure....
dropped to 40 once car was up to temp. Just jumped the gun a bit
thanks
Old 07-18-2003, 01:23 PM
.RJ
.RJ's Avatar
check your PCV and crancase vent systems, make sure they're not clogged up.
also, rev the motor to 3500 rpm or so while its sitting and see what oil pressure is there.
Old 07-18-2003, 01:32 PM
Audipwr1's Avatar
you think 40psi is too high for 2k at no load?
Old 07-18-2003, 01:34 PM
.RJ
.RJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Audipwr1 &raquo;</TD></TR><TR><TD CLASS="quote">you think 40psi is too high for 2k at no load?</TD></TR></TABLE>
sorry... you had posted before i hit 'send'
disregard
Old 07-18-2003, 01:38 PM
Audipwr1's Avatar
thanks RJ
I suspect the air in the line and sender skewed it, but once driven, shut down, and driven again the air escaped allowing a more accurate reading
Old 07-18-2003, 01:42 PM
.RJ
.RJ's Avatar
i assume this is a mechanical gauge then?
Old 07-18-2003, 01:44 PM
Audipwr1's Avatar
electrical, but going with the endyn site, i setup a remote system as to not put the added torque of a big sender on the block. ill post up some pics of the setup once i find a pace to host em
still have use of the stock warning light as well
Old 07-18-2003, 01:47 PM
.RJ
.RJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Audipwr1 &raquo;</TD></TR><TR><TD CLASS="quote">electrical, still have use of the stock warning light as well</TD></TR></TABLE>
stock warning light is useless..... it might as well be green and shaped like a dollar sign.
Old 07-18-2003, 01:48 PM
Audipwr1's Avatar
hehe i know, but what the hell i had to get a remote setup either way
Old 07-18-2003, 02:16 PM
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
stock warning light is useless..... it might as well be green and shaped like a dollar sign.</TD></TR></TABLE>
oh god that made me laugh for like 5 mintues straight
thx
Old 07-18-2003, 02:37 PM
AzG35's Avatar
Default Re: idle oil pressure (irev210)
Are you sure it doesn't drop when the motor heats up more? My car on cold start up will read about 60psi, then drop to 30-40 after 5 minutes, then once its completely warm will be between 15-20.
trulyshavedintegra
12-09-2012 05:06 AM
dragvixen
07-10-2009 11:20 AM
sasinorm01
11-21-2006 07:26 PM
platinum00
05-14-2006 06:40 AM
fanta!
08-11-2005 02:34 PM
Quick Reply: idle oil pressure
