idle low.... TB too big?
Old Aug 7, 2003 | 12:38 PM
b16a1civichb's Avatar
Default idle low.... TB too big?
Would having too big of a TB cause the idle to be too low because of air velocity? My setup is in signature. TB is 66mm.
Old Aug 7, 2003 | 01:26 PM
Steve91's Avatar
Default Re: idle low.... TB too big? (b16a1civichb)
No. If anything, too big of a TB would cause high idle. Play with the bleeder screw and adjust the idle up a bit.
Old Aug 7, 2003 | 08:37 PM
Default Re: idle low.... TB too big? (Steve91)
I did that, but didnt help.
Old Aug 8, 2003 | 06:56 AM
Xsi's Avatar
Xsi
So even with the idle screw wound right up it's still too low?
Old Aug 8, 2003 | 07:06 AM
Default Re: (Xsi)
well it says to disconnect the IAC valve to adjust idle but, when I do that the car shuts off.
Old Aug 8, 2003 | 07:18 AM
preluder's Avatar
Default Re: (b16a1civichb)
when you change the idle you have to jump the computer too. No vacuum leaks perhaps tell us what you have first on your car that you modified. THat would help ya know.
Old Aug 8, 2003 | 07:42 AM
Default Re: (preluder)
Well I installed a Skunk 2 Intake manifold on my B16 and a 66MM TB. With my OEm TB it idles fine but when I installed the 66 once the care is warmed up the idle is jumps from 500 to about 400~450 at idle. It doesnt shut off but it does make the car shake alot.
Old Aug 8, 2003 | 11:15 AM
The manual doesnt say I have to jump the computer to adjust idle.
Old Aug 8, 2003 | 11:48 AM
arw321's Avatar
I would just deal with the bad idle.
My car idles like a bag. Lots of moderately modd'ed cars do.
james007
Apr 30, 2010 04:26 PM
killa_lude
Aug 16, 2003 08:33 AM
steve_s
Jan 22, 2003 02:06 AM
350z-tech
Nov 10, 2001 10:46 PM
