Idle seems very low?
Old Nov 10, 2001 | 08:10 AM
350z-tech's Avatar
Default Idle seems very low?
i did a bunch of research adn it hasnt helped me, i have a 2001 intergra type r and my idle is at like 300 rpm dam low!! well i had a problem last weeek where they had to lower my fp because my engine light came on. now it feels like it is going to stall when i am driving, any sugestions?
thx
Old Nov 10, 2001 | 08:42 AM
DR. ON POINT's Avatar
Banned
Default Re: Idle seems very low? (ihiustler)
play with ur idle screw thingy on ur intake manifold..should be good after that
Old Nov 10, 2001 | 09:24 AM
350z-tech's Avatar
yea i looked at my throttle cable and it seems a little loose so should i tighten it?
Old Nov 10, 2001 | 04:14 PM
DLB1994's Avatar
no don't tighten it then your car is going to idle up and down
just adjust the idle screw
Old Nov 10, 2001 | 04:32 PM
350z-tech's Avatar
Default Re: Idle seems very low? (DLB1994)
yo where is the idle screw?
Old Nov 10, 2001 | 06:07 PM
01geeser's Avatar
New User
on the t/b its the one with silicone on it clockwise is lower idle and counterclockwise is higher
Old Nov 10, 2001 | 10:46 PM
Smashback's Avatar
Default Re: Idle seems very low? (01geeser)
Are you talking about the flathead screw for the bypass or the hex head throttle set screw?
My car's idle has been hosing up since I put the BBK 62mm TB on. Fluctuating idle, idle "sticking" between 1000-1500 RPMs, etc.
I'm trying to get this fixed before the turbo goes on in a couple of weeks...
Oh, and my throttle set screw fell out, so I can't even adjust that until I get a new one
Arthas
Mar 14, 2010 09:08 PM
94typeR
Mar 28, 2007 05:49 AM
killa_lude
Aug 16, 2003 08:33 AM
