LS-T problem :- ( help
Old Apr 28, 2006 | 07:35 PM
spooledhonda's Avatar
* B A N N E D *
Default LS-T problem :- ( help
ok who want to help me out with a problem. my sl anit runnin rite. i have a uberdata system and i was running oppen down pipe (cus it was fun) for a while. and the O2 check wasn't going off so i thought they turned it off for me. not is desides it wants to come on so the car runs all funny. it's all boggy till it hits boost and around 3500rpms. i'm running a T25 with 450cc on a B18b1. whats might you think is the prob?
Old Apr 28, 2006 | 11:19 PM
abnaasefmb's Avatar
Default Re: LS-T problem :- ( help (spooledhonda)
sounds like a crapy tune or something has changed. do you have a wideband?
Old Apr 29, 2006 | 05:03 AM
coneheadsracing's Avatar
Default Re: LS-T problem :- (abnaasefmb)
did you pull the code, or are you assuming its your o2.
Old Apr 29, 2006 | 06:52 AM
hondaguyef's Avatar
Default Re: LS-T problem :- (coneheadsracing)
Alot of people assume that the check engine light should not come on when the car is put into open loop (Closed loop disabled). This is false. If your o2 sensor goes bad or loses voltage the ECU will sense it and throw the code even if the o2 sensor is not being utilized (closed loop disabled) w/ Uberdata.
If the code is infact the o2 sensor and replacing it makes the car run much better, then your tuner does not have closed loop disabled. You should go over this w/ him. Good luck.
Phil
Old Apr 29, 2006 | 07:07 AM
Soccerking3000's Avatar
Default Re: LS-T problem :- (hondaguyef)
yea i had an issue similar to that, when i got off the gas even though closed loop was disabled i would get a code for the primary O2 sensor, i would just pull the fuse and keep going.
Old Apr 29, 2006 | 09:44 AM
* B A N N E D *
NO it is a code 41 witch is a heater O2
Old Apr 29, 2006 | 09:45 AM
* B A N N E D *
thx phil
Old Apr 29, 2006 | 10:35 AM
hondaguyef's Avatar
Default Re: LS-T problem :- (spooledhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooledhonda &raquo;</TD></TR><TR><TD CLASS="quote">NO it is a code 41 witch is a heater O2</TD></TR></TABLE>
Swap out the o2 sensor.
Old Apr 29, 2006 | 08:50 PM
* B A N N E D *
i' got to make the down pips to put in it 1st lol
Koyoloeor
Oct 13, 2005 04:57 PM
inzecure1
Mar 18, 2004 10:43 PM
allmotorsi04
Nov 24, 2003 07:51 PM
spencedogg
13
Oct 28, 2003 06:45 PM
94civic2nv
Oct 6, 2003 04:00 PM
