I need a hardcore tech guy with this one...
Maybe, maybe not. 2 weeks ago I'm on the juice, in second gear and at about 6700 rpm I hear a explosion from under the hood. After that the car runs real bad and I hear a tapping sound from the valve area. I remove the spark plug wires one at a time and cylinder 2 seems to be the suspect.
I buy all new valves and springs and have the head decked and the head reassenbled. On start up I have oil leaking out the head like crazy and it's running even worst than before! I'm about ready to junk the engine. Any ideas on what could be up?!! Thanks in advance for you help!!
twizt2
twizt2
gaskets.... you didnt get the oil lines right... breather maybe...
all shots in the dark really, where abouts is the oil exiting the head?
what was the diagnosis? detonation? intake backfire? need a little more info to make a good suggestion, sorry
Did you re-assemble this? Perhaps you installed something backwards. Wheres it leaking from?
Not too much information given, so you can't expect a very informative reply.
where from the head is it leaking from?
Head gasket could be suspect. Or head wasn't machined properly. Or bolts weren't tightened to specification.
I'd say the headgasket. Was it not torqued properly? Was it installed upside down? Those things could easily make a huge *** leak.
could be any of those take tghe head off have it cheacked for squareness. then check the headgasket. more times than not its prolly the head gasket. are you installed right the gasket will say u on it so i doubt it.
I really some help!
