need help!!!!! no oil pressure!!
Old Jan 16, 2002 | 06:20 AM
y2kgixxer's Avatar
Default need help!!!!! no oil pressure!!
ok guys I need your help, I just had my b16 head rebuilt (bent 3 exhaust valves)
before the head was rebuilt I had about 60-80 psi oil pressure (at start-up) now that
the head is rebuilt I get 20psi and it drops to zero....but when I take out the oil
fill cap with the engine runing about 1/2 quart of oil sprayed out (never did that)
is there a possibility that the guy left a plug out or put a plug where it \didn't belon???
I did notice a small leak on the timing belt side about 1-1/2" aboe the head gasket
any suggestions before I dissasemble the head again????
thanks in advance and sorry for the loooonng post
Old Jan 16, 2002 | 06:41 AM
Crazydave's Avatar
Default Re: need help!!!!! no oil pressure!! (y2kgixxer)
try a different guage..
do you hear any rods or valves knocking?
Old Jan 16, 2002 | 06:54 AM
y2kgixxer's Avatar
Default Re: need help!!!!! no oil pressure!! (Crazydave)
I did try the gauge and it works fine. and no there's no noises... engine idles and revs normal. (when I rev the engine the oil press goes to 20-25psi and then slowly back to zero. ) the head bas rebuilt because it had some exhaust valves bent.
Old Jan 16, 2002 | 07:48 AM
hensley's Avatar
There is a restrictor in the oil line to the head, sort of looks like a dowel between the block and the head, has a hole about 2mm in dia. thru it. This was probably left out or lost when the head was removed and or machined. I'll get back to you with more details. At present the oil is dumping to the head and not lubing the crank and rods.
Old Jan 16, 2002 | 08:17 AM
y2kgixxer's Avatar
Default Re: need help!!!!! no oil pressure!! (hensley)
the oil restrictor that is on the back side of the block is there and it is not clogged, I made sure I checked it before installing the head....it looks like I'm going to have to take the head out... ;-(
thank you to all who have responded..
Old Jan 16, 2002 | 08:40 AM
sgT's Avatar
sgT
There is also a dowel pin and o-ring under the #3 cam cam.
make sure thats there as well.
Old Jan 16, 2002 | 10:40 AM
y2kgixxer's Avatar
Default Re: need help!!!!! no oil pressure!! (sgT)
ok. just took out the cams... and like you said ....there's no dowel pin and o-ring....
off to the dealer ...........thanks again for all your help
victor
Old Jan 19, 2002 | 07:56 AM
y2kgixxer's Avatar
Default UPDATE !!!!Re: need help!!!!! no oil pressure!! (y2kgixxer)
I got the dowel pin and o-ring that goes on the #3 cam holder ...still no oil press.
and oil gussing out of the oil fill cap...took the head out this morning and the restrictor
plug still there.... what gives.... I'm sending the head back to the machine shop...
Old Jan 23, 2002 | 10:05 AM
y2kgixxer's Avatar
Default Re: UPDATE !!!!Re: need help!!!!! no oil pressure!! (y2kgixxer)
any other ideas...
does anyone have the service manual for the b16 motor, and would like to share some pics on the head oil flow (plugs, o-rings, dowel pins)
would be much appreciated,
Eddygee53
Apr 21, 2016 12:08 PM
EsotericImage
Oct 19, 2013 06:18 AM
brusk13
Jul 5, 2006 03:25 PM
93h22a1vtec
Dec 19, 2005 04:31 AM
sirwags
Jul 31, 2005 07:13 PM
