I need a hardcore tech guy with this one...
Old Feb 8, 2002 | 09:23 AM
twizt2's Avatar
New User
Default I need a hardcore tech guy with this one...
Maybe, maybe not. 2 weeks ago I'm on the juice, in second gear and at about 6700 rpm I hear a explosion from under the hood. After that the car runs real bad and I hear a tapping sound from the valve area. I remove the spark plug wires one at a time and cylinder 2 seems to be the suspect.
I buy all new valves and springs and have the head decked and the head reassenbled. On start up I have oil leaking out the head like crazy and it's running even worst than before! I'm about ready to junk the engine. Any ideas on what could be up?!! Thanks in advance for you help!!
twizt2
Old Feb 8, 2002 | 09:48 AM
twizt2's Avatar
New User
Default Re: I need a hardcore tech guy with this one... (twizt2)
I really some help!
Old Feb 8, 2002 | 10:50 AM
twizt2's Avatar
New User
c'mon, one of you guy has to know what's going on with my engine.
Help a brother out!
Old Feb 8, 2002 | 10:54 AM
Safir's Avatar
gaskets.... you didnt get the oil lines right... breather maybe...
all shots in the dark really, where abouts is the oil exiting the head?
what was the diagnosis? detonation? intake backfire? need a little more info to make a good suggestion, sorry
Old Feb 8, 2002 | 10:58 AM
EE_Chris's Avatar
Did you re-assemble this? Perhaps you installed something backwards. Wheres it leaking from?
Not too much information given, so you can't expect a very informative reply.
Old Feb 8, 2002 | 12:27 PM
Jesse H's Avatar
Default Re: I need a hardcore tech guy with this one... (EE_Chris)
where from the head is it leaking from?
Head gasket could be suspect. Or head wasn't machined properly. Or bolts weren't tightened to specification.
Old Feb 8, 2002 | 12:52 PM
Mike K's Avatar
Default Re: I need a hardcore tech guy with this one... (Jesse H)
I'd say the headgasket. Was it not torqued properly? Was it installed upside down? Those things could easily make a huge *** leak.
Old Feb 8, 2002 | 01:41 PM
iceburgslim's Avatar
Default Re: I need a hardcore tech guy with this one... (Mike K)
You didnt reuse the old head gasket did you? If so that's your problem. Also, did the knocking go away??
Old Feb 8, 2002 | 03:14 PM
rainforest's Avatar
Default Re: I need a hardcore tech guy with this one... (iceburgslim)
could be any of those take tghe head off have it cheacked for squareness. then check the headgasket. more times than not its prolly the head gasket. are you installed right the gasket will say u on it so i doubt it.
Old Feb 8, 2002 | 06:28 PM
slowestcivicever's Avatar
Default Re: I need a hardcore tech guy with this one... (rainforest)
Is the knocking still there?
Old Feb 9, 2002 | 07:39 AM
dirtySOHC's's Avatar
Default Re: I need a hardcore tech guy with this one... (slowestcivicever)
head gasket if its leaking oil like crazy and if its still knocking you may have turned your rod bearings (not good).
djb97ek
Apr 11, 2010 09:00 PM
red-si-eg..
Dec 21, 2007 06:40 PM
aznej2
Nov 21, 2006 02:12 PM
boostinb18
Aug 8, 2002 06:47 PM
y2kgixxer
Jan 23, 2002 10:05 AM
