i keep getting a CEL? WTF???
Old Nov 6, 2003 | 11:25 PM
turbohf's Avatar
Default i keep getting a CEL? WTF???
first off before i forget, here is my setup: 88 CRX HF, B18A1, Zdyne SECU Gold, turbo'ed...think thats all..
the other day my car threw a CEL #1, no problem just reset it.... throws it again later that day, k so the O2 is accually bad. swap it for another (used) that has worked before...threw a code... **** it i will just go buy NEW one [throws #1 again on the way there]. come home and install it and it DOES IT AGIAN!!! well i have been having another issue with my tach not working so i swapped out my engine harness with another one (both 88 HF harness both known to work and have been used in this car, origanal is back in) TACH WORKS! throws O2 code still! [just proving its not wiring like the tach]
after every time it throws a code i reset the ECU by pulling the hazard fuse.
what the hell is up? i try 3 differenet O2's, wiring looks fine and didnt have a problem till i started spinning the clutch?
so any ideas? im sure its something stupid im over looking (usually is). need to get this solved before i hit the dyno.... thanks!
Old Nov 7, 2003 | 10:52 AM
turbohf's Avatar
Default Re: i keep getting a CEL? WTF??? (turbohf)
Old Nov 7, 2003 | 12:09 PM
poison's Avatar
Sounds like a problem with the wiring. Grab a digital multimeter and test the wires for it leading to the ECU pinout.
Old Nov 7, 2003 | 01:33 PM
RCautoworks's Avatar
Default Re: i keep getting a CEL? WTF??? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a problem with the wiring
Yep, defiantly sounds like a wiring issue.
Old Nov 7, 2003 | 09:02 PM
turbohf's Avatar
Default Re: i keep getting a CEL? WTF??? (90blackcrx)
umm, didnt i say i changed the wiring harness and it WORKED LAST WEEK....
Old Nov 8, 2003 | 08:35 AM
Maybe the ecu is messed up
Old Nov 8, 2003 | 12:04 PM
doublejz's Avatar
check your plugs, if your running really rich then that can screw up your o2 sensor. just a suggestion
Old Nov 8, 2003 | 05:12 PM
CleenSi
Guest
Posts: n/a
Default Re: i keep getting a CEL? WTF??? (doublejz)
try unscrewing the MAP sensor a little, and move it back towards the intake...cuz there is sum play in it and this will cause your ecu to throw a **** load of codes...
this exact same thing happened to me then imoved it back, and screwed it in tightly all the sdden my idle is normal, not buning so rich n e mor, and o2 sensor works?
make sure u reset the ecu after doing it tho.
good luck
P.S. map sensor is very touchy.
KINGVEM^^ED6
19
Oct 12, 2011 03:42 PM
srv3fender
Mar 2, 2005 10:05 PM
srv3fender
Mar 2, 2005 09:19 PM
xtrafastcivic
Sep 19, 2004 10:16 AM
A11MotorR
Jul 5, 2002 04:42 AM
