How important are titanium retainers?
Old Nov 7, 2002 | 02:39 PM
SIReg9's Avatar
Default How important are titanium retainers?
How important is it to use titanium retainers? I heard they wore out fast. But i dunno, can some one give me some info on these? thanx alot
Old Nov 7, 2002 | 02:47 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: How important are titanium retainers? (SIReg9)
Yes they are a wear item. What do you plan on doing? They lighten up the valvetrain for increased rev range. Usually ITR retainers are fine.
Old Nov 7, 2002 | 02:50 PM
SIReg9's Avatar
Default Re: How important are titanium retainers? (Mr Milano)
Im puttin in CTR cams and skunk2 valve springs in a B16 head, Itr manifold, on a gsr block with JDM B16 pistons. Chipped ecu with 9600 rev limit. Just wondering if i should go ahead and drop em in while everything is apart
Old Nov 7, 2002 | 02:57 PM
Mr Hammond's Avatar
a/k/a Jomo
Good lord man are you nuts? Those cams barely make power up to 9,000rpm. What is the world do you wanna put a 9600rpm limit on there for? Assuming most take their motor right up to the rev limiter.
Old Nov 7, 2002 | 05:34 PM
littleredhatch's Avatar
yeah especially with no head work
Old Nov 8, 2002 | 08:54 AM
SIReg9's Avatar
Default Re: How important are titanium retainers? (littleredhatch)
I just traded my stock ECU straight up for it... I dont plan on takin her all the way up. I lost nothin in the trade so y the hell not
Old Nov 8, 2002 | 09:51 AM
Rob Dizzle's Avatar
if you wana rev that high safely, of course you will need
ti retainers,
portflow inner/outer valve springs
lighter valves
ferrea keepers
balanced bottom end
maybe block girdle
9600 rpm is really high
you shoulld never need to go there if, if you mis shifted, then that would be a case where it could happen
Old Nov 8, 2002 | 10:23 AM
2 0 3's Avatar
Default Re: How important are titanium retainers? (Bob-DC2)
just wondering cause im abotu to buy retainers and springs also,
im using b16 bottom with b16b pistons , head is b16a ported portmatched and toda spec b's
what spring retainer combo should i go with and how high can i bring revs up to with this set up? i was hping to turn 9's , is this to risky ?
Old Nov 9, 2002 | 06:31 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: How important are titanium retainers? (allmotorDA6)
TODA valve springs and if you must Portflow ti retainers. ITR valves or any forged valves would be nice too while you are at it. You could run flat ones for a few tenths more comp. Those B's comp. You can take that set up to 9600 and the valvetrain could see 10K. I'd be more worried about your bottom end once you are that high. Yes it's a B16, but still balence, blueprint, knifedge while you are there and shot peened rods would be nice. Or you could just get the Toda bottom end.
levee000
12
Aug 28, 2008 04:03 PM
civic4g63
Apr 30, 2007 08:18 AM
TreeToTall
Apr 19, 2006 06:33 PM
Waachback
11
Aug 10, 2004 02:41 AM
HondaLife
14
Mar 8, 2003 12:33 PM
