How do I take out the shift linkage???
Old Jan 29, 2006 | 08:43 PM
sifoo's Avatar
Default How do I take out the shift linkage???
Hi All,
As you all know there are two parts of the linkage, one that connects in the trannie and the other thats bolts up to the side of the trannie.
How do I removes the linkage thats connected inside the trannie?
Is there a special way? Special tools?
FYI its covered with a small boot
What should I do?
Old Jan 29, 2006 | 08:57 PM
shorto85's Avatar
Use a punch to remove the pin that holds it in. You'll see it if you pull back the rubber boot.
When I did my swap I couldn't get that pin out so I just left it attached and unbolted it at the shifter. Once it was out of the car I was able to get it out no problem.
Old Jan 29, 2006 | 10:13 PM
sifoo's Avatar
Default Re: How do I take out the shift linkage??? (sifoo)
ok thanks for the reply
but whats a punch?
Old Jan 29, 2006 | 10:53 PM
EnzoSpeed's Avatar
It's a chisel-type tool that comes to a point - you use it by lying underneath your car and beating on it with a sledge hammer until your shoulder muscles burn so bad you want to cry.
vtecc
Jun 1, 2015 10:53 PM
Matt_Jagg7
May 13, 2010 01:18 AM
ALLMOTOR CRX
11
Mar 29, 2007 07:34 AM
say_xiong
Sep 21, 2006 11:34 PM
ScootinIntegra
Apr 7, 2004 12:44 AM
