How to do a heater core flush?
Old Nov 16, 2007 | 10:00 AM
WhiteOnRice's Avatar
Default How to do a heater core flush?
This is on a 89 CRX Si. Nobody seems to know how.
Garden hose into the inlet/outlet? How do I force the water out after I flushed it?
Old Nov 16, 2007 | 07:11 PM
Transpoquick's Avatar
Default Re: How to do a heater core flush? (WhiteOnRice)
I feel your pain it's gettin cold, Disconnect the connections @ the firewall and you'll have to rig up some kind of piece so you can hook your garden hose up. Doesn't matter which side you flush from just make sure there is'nt any valves in the way that would stop or inhibit flow.BTW on a 89 (thats pretty old for our neck of the woods) you might be ready for a new core, in-fact I would pull the hole damm kit and cabootle now and do a heater core so your not freezing you a#@ off in the middle of winter. Check all hoses for obstruction, Is the water pump good? burrrrrrrrr
Old Nov 16, 2007 | 07:44 PM
all-mtr-teg's Avatar
Why can't you just flush the whole system, like a radiator, turn the car on, get it hot, turn on the heater full blast then do a flush like normal, won't that get the gunk or debris out of the heater core also
Old Nov 16, 2007 | 08:26 PM
Default Re: How to do a heater core flush? (all-mtr-teg)
NO, you'll just blow all that crap around the rest of the motor and RAD.
Old Nov 16, 2007 | 10:38 PM
No way I'm replacing the core if I don't have to. That is a huge PITA. The crx only blows warm air (best through defrost vents). I'm hoping the flush will do the trick. Valve opens/closes fine also.
Old Nov 16, 2007 | 11:26 PM
Default Re: (WhiteOnRice)
Agreed, however thats a 89 crx from around here I'm guessin. I hope evrything works out fine for you.
Old Jan 25, 2008 | 04:29 PM
themorphious's Avatar
bump this, i need help as well....it's 9 deg. tonight....
Old Jan 26, 2008 | 12:20 PM
IN VTEC's Avatar
They make tools that use compressed air to vacuum all of the fluid out of the cooling system. The same tool will also allow you to replace the vacuum with coolant. 5 minutes and it's done. It's mighty ****.
andyz
Apr 6, 2022 08:14 PM
ge_ej1
Nov 11, 2008 08:57 PM
dacrxkid4rm253
10
Jan 30, 2008 01:20 PM
justseeingifitistaken
Apr 7, 2007 09:17 PM
carlip
Nov 15, 2005 06:34 AM
