how to check if distributor is not bad
Old Jul 17, 2002 | 08:54 AM
nosmas's Avatar
Default how to check if distributor is not bad
I have b16a2 and wanna know how do u check to see if the distributor is working or not cuz my motor wont start need help on ways to check the distributor
Old Jul 17, 2002 | 09:47 AM
EE_Chris's Avatar
Default Re: how to check if distributor is not bad (nosmas)
Did you check for spark yet? If not, take out one wire/plug and touch the ground strap to a clean ground. Have someone crank the engine over a few times and check for a healthy blue arc.
To somewhat check it out, you need a DMM (digital multi-meter). With this you can check the resistance of the ignition coil (primary & secondary) and the resistance of the 3 sensor coils'. You could also check that B+ is getting to the coil/igniter along with pseudo-checking the igniters input from the ECU [it should be pulsing, so your meter should register something].
lipuid
12
Apr 4, 2008 01:08 PM
preludepower01
Sep 3, 2007 08:07 AM
Brian_92GSR
May 21, 2002 04:46 PM
