floating piston wrist pin clip question
Old Jul 16, 2002 | 08:15 PM
GruvyTune's Avatar
New User
Default floating piston wrist pin clip question
on the JE pistons, is there a particular trick to putting the wrist pins on? I used alot of pressure and a screwdriver. I did scratch the piston a bit but in that location it really shouldn't matter.
Someone told me you should clock the clips to up or down. Is that really necessary? I can't imagine them moving anywhere!
Old Jul 16, 2002 | 11:59 PM
sparkz's Avatar
Default Re: floating piston wrist pin clip question (GruvyTune)
what kind of rods are these pistons going on to? stock rods with aftermarket pistons need to have the wrist pins punched in, shouldnt need the clips.
Old Jul 17, 2002 | 04:38 AM
GruvyTune's Avatar
New User
Default Re: floating piston wrist pin clip question (sparkz)
eagle rods
Old Jul 17, 2002 | 09:57 AM
GM2000ITR's Avatar
New User
The clips are a lot sronger than you think they are! Start at one end of the clip and work it spirally into the clip relief with a small screwdriver. Keep pressure on it at all times until it is in or it will simply pop back out & you will have to start it again. The first 1-2 will give you a headache, but the rest will happen easily & quickly! Good luck!
[Modified by GM2000ITR, 10:57 AM 7/17/2002]
D-SOHC 05
Nov 16, 2007 05:20 AM
LSVTECoupe
Dec 26, 2003 04:05 PM
Alstare
Nov 25, 2003 09:02 PM
EF
Apr 2, 2002 12:40 AM
