No spark in a GSR
Old Jun 3, 2009 | 11:38 AM
aguynamedpat's Avatar
Default No spark in a GSR
Well my buddy picked up a 95 GSR with a B18C in it the other day. Well, we compression tested the car, and after we were done we could not get any spark. We are definitely getting fuel, but we are not getting any spark.
The coils in the distributor tested good and the ignition control module tested good as well. We still have to make sure the distributor is getting power from the ECU.
Its not timing related, the rotor turns when you turn the car over. It will just keep turning over but wont crank. The cap and rotor look to be in good shape as well.
Anyone have any ideas?
Old Jun 3, 2009 | 08:27 PM
jdmda6xsi's Avatar
Default Re: No spark in a GSR
what did you do to disable the ignition and fuel during your compression check?? ran before, now it doesnt.....did you forget to put your ignition fuse back in after your check???? more details please
Old Jun 3, 2009 | 10:43 PM
Ruben19's Avatar
main relay,
Old Jun 4, 2009 | 04:38 AM
fcm's Avatar
fcm
Old Fart
Same questions^^^
Did it run before the comp check?
Do you have power on the black/yellow lead going to the distributor assembly? 94
Old Jun 4, 2009 | 02:56 PM
vue-k's Avatar
yea more info needed
Old Jun 4, 2009 | 07:30 PM
KWayRacing's Avatar
If you didn't disable the ignition maybe you shorted the coil out. I hear coil tests good You mean resistance checks? I have seen many coils pass resistance check tests and be faulty. Same as above more infoplease.
NWsleeperswaps
Nov 24, 2015 12:31 AM
GoSickemRobert
Engine Management and Tuning
Aug 3, 2011 11:07 AM
aguynamedpat
Jun 4, 2009 03:32 AM
eagle459
Sep 1, 2008 03:06 PM
hmtcrxsir
Jul 10, 2007 11:41 AM
