how to adjust timing on a h22
Old Feb 16, 2003 | 09:24 AM
accorracer's Avatar
Default how to adjust timing on a h22
i tried to turn the distributor on my friends h22a4 and it felt as though it were in a fixed position, is the h22a the same way?
if you can't change it by the distributor then how?
Old Feb 16, 2003 | 10:00 AM
satan_srv's Avatar
Default Re: how to adjust timing on a h22 (accorracer)
You can't. OBDII preludes have the CKP sensor by the crank pulley, even if you could turn the distributor it wouldn't do anything.
The only way to change the timing is to reprogram the ecu.
MastaFlyMason
Oct 2, 2016 02:53 PM
bnmm
Engine Management and Tuning
May 27, 2011 05:28 AM
jakscivic
Jun 2, 2010 07:29 PM
turboH22Aakkord
Jul 6, 2005 01:09 PM
Wide Open Throttle
May 29, 2002 03:29 PM
