HOW TO ADJUST THE CLUTCH????
Old Jul 29, 2006 | 11:38 AM
KMk51188's Avatar
Default HOW TO ADJUST THE CLUTCH????
whats going on ht someone told me you can adjust ur clutch alot lower because mine catches wayyyyy too high it i was thinkin either my clutch is gone or i really could just ajdust it lmk
Old Jul 29, 2006 | 12:09 PM
civicstar's Avatar
Default Re: HOW TO ADJUST THE CLUTCH???? (KMk51188)
if you have a cable clutch you can adjust it, just tighten the cable where on that bracket near the clutch fork. if its a hydro, you can only bleed it. but most of the time, your clutch is not grabbing because its warn out and you need a new one
Old Jul 29, 2006 | 12:32 PM
KMk51188's Avatar
Default Re: HOW TO ADJUST THE CLUTCH???? (civicstar)
k but I think I do need a new clutch because even when I take off out of first ill shift at 5500 n it sounds like I'm over revving it when I shift lmk
Old Jul 29, 2006 | 05:41 PM
JimBlake's Avatar
If it's a cable clutch you want to loosen the cable. Besides, you didn't say whether it's a hydraulic clutch...
But since it slips when you shift, that probably means your clutch is shot.
danno33
12
Sep 30, 2012 08:46 PM
I8ayellowcrayon
Aug 23, 2004 07:18 PM
DroppedTegLS
Sep 28, 2002 01:51 PM
PolySquared
Feb 12, 2002 10:47 AM
