Major steering problem. Please help.
Old Jan 19, 2002 | 06:23 PM
OneThirtyEight's Avatar
Default Major steering problem. Please help.
I have had this steering problem for quite some time now. THe steering feels like it has slack in it, like I move the wheel and nothing happens. feels very light and drifty, like the steering needs more resistance, the wheel seems to move on its own also. I know my shocks and tires are total crap , but I dont think that is the problem, it seems like its comming from my steering, I had the rack adjusted once, ive had 2 alighnments recently. Anyone that can help me please do. I have to get some new tires anyways, so Ill se if that helps, I will try some S-03's
[Modified by 97blackteg, 10:34 PM 1/19/2002]
Old Jan 19, 2002 | 07:44 PM
hatchy's Avatar
Default Re: Major steering problem. Please help. (97blackteg)
Check your wheel bearings. Jack up your car and wiggle the each wheel and see if there is any play.
Old Jan 19, 2002 | 09:19 PM
Default Re: Major steering problem. Please help. (hatchy)
both wheel bearings have also been removed, regreased and checked.
Old Jan 20, 2002 | 09:14 PM
anyone else?
Old Jan 20, 2002 | 10:09 PM
LoStreet94's Avatar
Inner or outer tie rod ends?
Old Jan 20, 2002 | 11:06 PM
obd1canobie's Avatar
New User
Default Re: Major steering problem. Please help. (LoStreet94)
How do you grease a sealed bearing that is pressed into the knuckle, then has the hub pressed into that? Last I looked the only grease fitting in the front end of a Honda was the steering rack on a 1978 Accord LX.
Old Jan 22, 2002 | 06:44 PM
Default Re: Major steering problem. Please help. (obd1canobie)
More and more im thinking its my caster. I read about the caster, and it sounds like the exact problem I am having. Im *thinking* about putting my stock springs back on my car, I dont know though, that would look SOOO ghetto.
[Modified by 97blackteg, 10:46 PM 1/22/2002]
Eee Kayyy
Apr 16, 2019 09:58 PM
gqstatus05
Dec 12, 2007 12:40 PM
AutoXMan
Nov 22, 2005 10:04 PM
buzlink
Nov 17, 2005 12:04 PM
JoKarma
Sep 20, 2005 10:56 AM
