Horrible Ride
Old Nov 23, 2001 | 11:56 PM
HondaCutter's Avatar
Default Horrible Ride
Lately my car has been riding very bad (bumpy, car is trying to steer itself)
it's been making me mad, I can't drive so fast cause I'm scared the car is just gonna lose control. I have the tokico suspension package, and 17 inch CP -35's. I also have 3 brand new tires and one that's really bad(don't ask). Please help me out, tell me what you think is causing it or what I do to prevent it. Thanks in advance.
Old Nov 24, 2001 | 12:14 AM
OneThirtyEight's Avatar
Default Re: Horrible Ride (HondaCutter)
Get rid of that tire, get all 4 same tires.
Than do the following
-Alignmnet
-Good computer balance
-Tighten steering rack
I had the exact problem, this fixed it, all 3 issues were the culprits.
[Modified by 97blackteg, 4:15 AM 11/24/2001]
Old Nov 24, 2001 | 07:24 AM
Cool thanks, do I need a camber kit for the alignment?
Old Nov 24, 2001 | 09:36 AM
depends on how low it is, camber does not usually effect the ride quality too much. So I dont think thats your problem, but toe, caster, and all that can.
Old Nov 24, 2001 | 10:07 AM
Max GSR's Avatar
Sounds like excess torque steer caused by an alignment problem. Do the alignment first and see what your camber is after that. If it's approaching -2 degrees or more, then start checking into a camber kit.
Old Nov 24, 2001 | 10:56 AM
internet ay's Avatar
Default Re: Horrible Ride (Max GSR)
how do you tighten a steering rack??
Old Nov 24, 2001 | 01:18 PM
Max GSR's Avatar
Default Re: Horrible Ride (internet ay)
It's not practical to "tighten" a steering rack. The adjustment "screw" is waaay too finicky. Better off replacing the rack bushings with Energy Suspension, or similar polyurethene bushings.
Old Nov 24, 2001 | 04:33 PM
DR. ON POINT's Avatar
Banned
i second tht
Old Nov 25, 2001 | 07:58 AM
r30slick's Avatar
One reason you would still be noticing torque steer is because the axles are not the same length from the wheel to the transmission. Because the transmission is located on the right side of the car when you are sitting in it, the axle length to the left wheel is longer than the right causing torque steer to the right wheel. Now I am not absolutely sure about a '99 civic but I believe that it is this way. To fix it on your model im not exactly sure. Also when a car is lowered you now have rack and pinion steering. So you really don't need your power steering. Plus this is taking away a couple hidden hp. Any bump you will hit can cause your wheels to jerk. Do what the other posts say and you should be better off. Although you can never get rid of this problem completely.
mikbik
13
Aug 28, 2015 03:03 AM
HWKR3W
Dec 19, 2010 01:46 PM
POWerTuner
Suspension & Brakes
Oct 29, 2007 04:45 PM
projectej8
Nov 27, 2004 12:12 PM
NCSTIdriver
Jun 23, 2003 03:04 PM
