hondata problem
Old Aug 15, 2002 | 10:57 AM
torran's Avatar
Default hondata problem
i just bought a stage 2 and here is my problem. my vtec doesn't work, all solder connections are good because i am a NASA qualified solderer, anyways when i plugged in everything, the red light blinked once and then stayed steady...good right. i'm thinking i got a bad chip, but how could that be because the car runs, or does hondata not send out chips with vtec until you get it tuned. if your wondering i have a 00 si. all mods have been taken care of to asure that the hondata works. any help or info would be appreciated.
Old Aug 15, 2002 | 11:01 AM
Spade's Avatar
Default Re: hondata problem (torran)
Just because the engine works doesn't mean the ECU is good.
Old Aug 15, 2002 | 11:03 AM
eg6ajk's Avatar
what ecu is it? what chip? what other components have you installed (74hc373?)
Old Aug 15, 2002 | 11:10 AM
torran's Avatar
i have a p28. i installed all necessary chips that came with it.
Old Aug 17, 2002 | 04:54 PM
E Swift's Avatar
You may need to redownload the software onto the chip.
Old Aug 18, 2002 | 01:45 AM
sparkz's Avatar
Default Re: hondata problem (E Swift)
could be a couple of things:
the dealer you bought it from maybe perhaps set the vtec too high (ie 8000)
or maybe they put an ls base map on it
Old Aug 18, 2002 | 12:16 PM
C-speed's Avatar
What gives you the indication that VTEC isn't working?
Silverbullet114
Engine Management and Tuning
Jun 25, 2008 11:29 AM
dnatrance
Mar 23, 2005 01:57 PM
lemongreenhatch
Aug 21, 2004 04:46 AM
Mr.DC2TurBo
Jun 29, 2004 05:26 PM
