Need help, PR4 code 5??
Old Aug 16, 2002 | 05:14 PM
Flexmyrex's Avatar
Default Need help, PR4 code 5??
my ecu is throwing code 5
91 ls. thnx in advance
Old Aug 16, 2002 | 05:22 PM
BR's Avatar
BR
Default Re: Need help, PR4 code 5?? (flexmyREX)
Code 5 is your MAP (Manifold Air Pressure) sensor.
Check the connection going to it and see if there is any fried wires or anything. I have never come across a bad MAP sensor before so I cant help you much more than that.
Later,
BR
Old Aug 18, 2002 | 09:38 AM
Flexmyrex's Avatar
Default Re: Need help, PR4 code 5?? (BR)
ok ill check , for the help
Old Aug 18, 2002 | 01:26 PM
ShootingStar's Avatar
Broken or loose vaccum line will do it. I had the same code a few days ago and the steel "spider web" on the back of the IM near the firewall was broken at the weld. I just ran a temp piece of vac hose until I get a new one.
[Modified by ShootingStar, 10:27 PM 8/18/2002]
DA_zooooms
Aug 10, 2009 09:08 PM
d_boi_swag
Jul 5, 2009 12:14 PM
blacksi-t
Sep 21, 2003 01:21 AM
k4ff1n3
Sep 28, 2002 12:15 PM
Flexmyrex
Aug 16, 2002 08:46 PM
