High Comp. Hesitates. No Power. Runs hot. Dies Up Top
These are some of the issues I am having with my car.
I did a compression check and it was 225 psi all across, with 8.5:1 pistons The car with bog/hesitate just when its about to come out of vacuum, anywhere from 5"hg and 0. The power band is completely pushed up in RPM range and all power dies up top. I used to make 240 TQ by 5k and hold that 240 to redline and now i just make it at 6800 and it immediately dies off. And it also seams to run slightly hotter Any ideas? |
Re: High Comp. Hesitates. No Power. Runs hot. Dies Up Top (rdssk8rcs1)
Are you throwing any codes ?
It sounds like the vehicle maybe running lean. What engine management are you running ? |
Re: High Comp. Hesitates. No Power. Runs hot. Dies Up Top (mtber)
how is it high comp. with 8.5:1 thats not high sounds like the motor is built for turbo and its not hooked up
Re: High Comp. Hesitates. No Power. Runs hot. Dies Up Top (superfast666)
Sorry, i should have stated my set up before.
ls/vtec W/ pistons and rods gsr head/tranny revhard turbo kit 1000cc injectors tuned with hondata |
so its boggin out on the top end sounds like fuel but you have huge injectors maybe its a fuel pump or pressure regulator
Air fuel seams to be good all the way up. 12.0:1 ish all the way up
that dosent make sense
Heres my old dyno sheet @ 15psi....
https://i64.photobucket.com/albums/h...tDynoSheet.jpg And heres my new dyno sheet on the same exact set up except bigger injectors... https://i64.photobucket.com/albums/h...4/HPIM1029.jpg Modified by rdssk8rcs1 at 11:17 PM 7/7/2008 |
Take the car back to your tuner to have it checked out. Trying to diagnose this over the net is going to be difficult.
I was hoping to just come up with some ideas
maybe the new bigger injectors are crappin out on the top end
any reason why you switched to bigger injectors i dont really see a problem with the first dyno graph it looks pretty good.
Re: (unusual71)
Well after that tune, went back again @ 21 psi and was starting to reach too high of a duty cycle
