Lighting HID/Xenon kits, Retrofits and Associated Topics
plz some help
Old Oct 25, 2012 | 06:34 AM
vip001's Avatar
Default plz some help
Just installed new Bosch hid xenon on my 2007 accord with low beam lamps, The problem is when i turn the low beam on, The fuses of low beam blown up.
i checked up the hid kid with another car and its working fine but on my accord when i turn the headlights on the low beam fuses just damage.i changed the fuses but the problem still exist.
note:when i remove the new HID and return the factory one the problem is gone.
Old Oct 25, 2012 | 08:59 PM
Joon Joon's Avatar
Default Re: plz some help
hopefully you didnt pay much for that kit.. bosch doesnt make kits unless they are for oem setups like d1/d2/d3/d4 bulbs.. are you running a relay harness? only reason, i see the fusing popping is because something is shorting out..
Old Oct 27, 2012 | 06:52 AM
vip001's Avatar
Its about $70,There is a factory one relay and I'll have someone check up if there is a shorting. I appreciate your help
jk7701
Jun 7, 2010 05:10 PM
sndttan88
Jul 2, 2009 10:14 AM
crazyfast
Nov 8, 2008 11:15 AM
Devine
Nov 28, 2005 02:31 PM
